All of a sudden my screen does not rotate anymore.
I went onto settings to make sure the auto lock switch is not checked.
What else can I do ?
Rob ....
This is a discussion on Screen does not rotate within the iPad 2 Forum forums, part of the Apple iPad Discussions category; All of a sudden my screen does not rotate anymore. I went onto settings to make sure the auto lock switch is not checked. What ...
Rob ....
Tried a complete cold re-boot? Other than that all I can think of is a system restore.
I switched the setting on & off and now it works.
Thanks for your reply.
BTW .... what's a cold reboot ?
Rob ...
You should try checking the auto-lock option, then flick the volume button and see if that helps.
If that doesn't help, then try a hard reset.
Otherwise, if you have the time, restore.
EDIT - ninja'd.
BTW, it's also known as a hard reset. It's when you hold the Power and Home button for 10 seconds and it reboots.
They say a car represents your personality. I have no car.
