Someone please tell me how do I access a complete drop down list to make a selection that is not visible unless you scroll down. The touch screen does not seem to allow you to scroll. See attached pic. I need to select for example year 10.
After you click on the drop down menu you should be able to just touch on the area and scroll up or down.
sent from my Ipad 2 32g Wifi
@ Veritas4420 I tried that it doesn't work. Some websites it does others not so...ughhh
Have you tried the two fingered touch, two fingers inside the drop down box and scroll up and down, I haven't found a situation where it hasn't worked yet but I'm certain there will be a first!
Oh wow!!! Thanks much, the 2 finger scroll works...
I learnt that one from our very own Tim Spracklen......so thanks Tim!Originally Posted by Lovemyipad2
This has been bugging me as well. Two fingers does the trick!
Thanks guys!
Hmmm I've never used two fingers before, always works with just one. Guess I will have to try that.
