I am running an app that says my GPS is not running (my Airport is turned off). How do I turn on my GPS (the app is Navfree) - I Have an iPad2 with wifi and 3g
This is a discussion on Ipad 2 GPS within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I am running an app that says my GPS is not running (my Airport is turned off). How do I turn on my GPS (the ...
That happened to me. I think I did a shut down and then it worked. Good luck.
That sounds good advice. It's not possible to turn off GPS so a reset sounds the best solution to this problem. However, of course, it's possible to be in a location where the GPS signals are obscured and so GPS may not be 'working'
But get back to us if this doesn't fix the problem.
Make sure that location services is turned on.. Open location services in setup. You'll see a list of apps that use GPS.. Make sure your Navfree app is turned on.
Thanks for your input - you hit the nail on the head (I am one GPS enabled)Originally Posted by jwt873
Cheers,
rwillacy
