Trying to decide iPad2 or not?
This is a discussion on Trying to decide iPad2 or not? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I've never used an apple product before. I was certain I would be purchasing the Galaxy 10.1 today, until I went to the store last ...
Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 51
    81505
    Jul 2011
    5
    I've never used an apple product before. I was certain I would be purchasing the Galaxy 10.1 today, until I went to the store last night and saw both that and the iPad2 and now I am totally confused. The store clerk was not helpful, either - "if it's just for looking at pictures and listening to music, go with the iPad2, but if you want to use it for business, then get the Galaxy" Huh?
    I searched this forum and learned a lot about it, but there are a couple of things that are still not clear, whether the iPad2 supports or not, before I become an Apple customer. Sorry if these sound trivial, and if you think the info is somewhere on-line, just point me to it, I don't mind doing the reading and finding out. (BTW, Shouldn't a lot of this info be on the product manufacturer's page, instead of just marketing fluff?)
    - Don't need a data service contract, but I do need GPS. Would the wi-fi model suffice, or should I get the wi-fi/3G model and a maps program and just not activate a 3G contract?
    - Whether I get the 16,32, or 64 Gb I need to be able to access data on an external USF flash or usb HD drive. I've seen posts about the usb adapter from Apple allowing one to retrieve "pictures" from a usb flash drive, but I need to access more than pictures. Is there possibly a different adapter I can purchase, or something that would allow me to do that, *without* having to jailbreak the iPad2?
    - I know that the iPad2 is NOT a replacement for a computer, but I need some basic "office" functionality on it (view a docx file, compose a quick word document, put final touches on a power point presentation I may have created in MS-Office, etc.) Will I be able to do these things?
    Once again, sorry if my questions sound mundane, but for the first time I am seriously considering an apple device and don't know anything about them - I just want to make sure.
    116 times
    15,249
    Quote Originally Posted by Chtidio View Post
    Welcome to the Forum...I'll try to answer some of your questions - I'm sure other Members will help too.
    Only the 3G iPad has the GPS chipset because some of the GPS functionality is shared with the same chip that provides 3G. So the WiFi only model does not have GPS. If you have the 3G model, there is no need to activate 3G to use GPS.
    On a non-jail broken iPad you cannot access anything other than pictures using the camera connection kit...
    One of our members carried out a survey of Office apps for his company; you can see his conclusions in this thread...
    http://www.ipadforums.net/new-member...31-hi-all.html
    Another comparison was undertaken here....
    http://www.ipadforums.net/iwork-foru...omparison.html
    The Apple iWorks Office suite for the iPad has a set of useful Help pages that show their capabilities here...
    Pages is Word compatible and can read .doc and .docx files and save in .doc and .pdf
    Keynote is PowerPoint compatible and can read .ppt and .pptx files and save in .ppt and .pdf
    Numbers is Excel compatible and can read .xls and .xlsx files and save in .xls and .pdf
    Apple - Support - iOS Apps - Welcome
    iPad Ninja
    49414
    80 times
    North Carolina
    1,925
    Appears that Tim has addressed most of your questions and concerns; I'm fairly new to the iPad2 (although an iPod Touch owner for over a year, so quite similar interface).
    I bought the 32 GB Wi-Fi only model - already own a GPS device and did not want a 3G service plan - as to the amount of memory desired, I choose the middle option - my music is on the iPod, so no need to duplicate it on the iPad; plus, I'm not planning to load a lot of video on the iPad - thus if you're not wanting to put LOTS of music/video files on the device then let that help you decide. Keep in mind that extra memory cannot to added via USB thumb drives, SD cards, etc.
    Now the Wi-Fi has a crude positioning system that relies on contact w/ several active Wi-Fi hotspots (if you are in range!) - uses triangulation; however, if you need precise positioning information (like using the device for driving), then a GPS will be needed as already mentioned - more information HERE.
    Finally, the iWorks apps are quite good (I'm using Keynote & Pages) - certainly not as powerful as their MS equivalents; keep in mind that there are plenty of ways to transfer files into the iPad w/o the use of external drives, cards, or others. Also, if you plan to do a LOT of note & document writing on the iPad, you will likely want a physical keyboard - I have the BT Apple one but many other stand alone & cover integrated options exits.
    Good luck in your choice(s) -
    iPad Addict
    37720
    6 times
    Colonial Heights,Va
    1,395
    Galaxy can read documents out of the box of pdf and Office. For writing Office type documents, both devices need apps.
    Galaxy requires a USB adaptor ($20) to read more than pictures but can transfer many formats of media with it.
    Though others will disagree the ability to use Flash native on the Galaxy has it's benefits for many Flash written sites that don't involve videos. The ipad has work around browsers that are hit and miss.
    Honestly either is a good choice but Android has a much better multi task ability than ios. If you don't need several things running, not sitting idle but actually running, that will be no big deal
    The Galaxy has both cell tower assisted GPS and standalone out of the box. If you get a 3g ipad you don't have to activate a data plan unless getting a contract price break, iow stores like Target and Best Buy don't require a data plan, it's pre pay paygo.
    Hope that helps.
    Welcome to the forum
    Support Our Troops!!
    This post was Tapatalk approved. Sent from an Incredible phone
    8253
    Jun 2010
    Wherever I May Roam
    55
    ...but if you want to use it for business, then get the Galaxy"..
    I use my iPad2 daily at work. I use it for forecasting, scheduling and note taking. I even modify various schematics (PDF) with GoodReader. I'm not sure why the salesperson told you to go with the Galaxy for business purposes and ignored the iPad's capabilities.
    White iPad 2 64GB (WiFi / 3G) Verizon White iPhone 4s 32GB AT&T
    iPad Addict
    37720
    6 times
    Colonial Heights,Va
    1,395
    Because they don't know what device does what.
    Support Our Troops!!!
    Sent from this Galaxy
    81505
    Jul 2011
    5
    Quote Originally Posted by GadgetGeek71 View Post
    Thank you and everyone else who has responded. The information here and having spent 10+ reading and following all sorts of discussions on-line has taught me alot about these new devices.
    I think the iPAD looks and feels better, but I am also seeing why the salesperson made the comment they made. I have no doubt that you do all these wonderful things on your iPAD on a daily basis. I thought of a fairly simple task that I need to perform and when I searched on-line on how to do it, I was taken aback by the absense of a simplistic iPAD solution.
    We have many PDF files being updated on our file server (at the office). Each file is 20-30 Mb and I need to look at 4-5 of them each day. I thought the iPAD2 would be a great tool for that. Nice inexpensive apps for PDFs in the Apple store (Fast PDF), great! One slight problem, how to get the files to it from our file server. Can't log on to the domain to transfer them, through wi-fi, without asking IT to do all sorts of mods on the server, can't just place them on a flash USB drive and transfer them that way (that would be ideal)... I could get GoodReader and then use Itunes to transfer them, and hope that they would transfer since the format is supported on the iPAD. Or I could use dropbox and have my files on someone else's server (my boss wouldn't be keen on that), or...
    It could be that I am just too thick to understand, but why should such a simple task of grabing a file from a Windows file server so I can read it on teh iPAD2, be so difficult? It doesn't make sense. Now, if all I wanted was to transfer pictures of videos, to the iPAD, the process would be a snap. Which brings us to the comment the salesperson made!
    I don't know that the equivalent process on the Galaxy would be simpler, now I have to go spend a few hours reading on that. But, based on what I've seen so far, I am not holding my breath :-( It could be that I am simply looking at the wrong tools, and I should stick to my laptop for doing work, and get a tab for fun things, I don't know.
    Not ready to give up yet, and if someone indeed has a simple solution to the simple task I have, I am more than willing to take another look, because I like the looks and feel of the iPAD2 (out of all the tabs I looked at). But it I cant' get simple things liek that done without extra effort, I cringe at what I may have to go through to do any complicated work with one of these new toys :-(
    81505
    Jul 2011
    5
    Quote Originally Posted by Mountainbikermark View Post
    Galaxy can read documents out of the box of pdf and Office. For writing Office type documents, both devices need apps....
    Thanks, but as I read more on these devices I realize that I may have to stick to my laptop for *real* work I need to do, for a while, yet :-(
    Some tasks may be easier on teh Galaxy than the iPAD, as you described, but unless I am totally missing something here, transferring data and accessing data from Windows networks is still a tricky task :-(
    One thing I can not emphasize enough, is how much I have learned from teh on-line community in the past couple of days. Didn't help me decide what to do, but I feel I have a better understanding of these devices (I think <g>).
    iPad Addict
    121
    86 times
    Jan 2010
    Seattle, Washington USA
    1,293
    We have many PDF files being updated on our file server (at the office). Each file is 20-30 Mb and I need to look at 4-5 of them each day. ...
    No, you're not being thick. Apple does a wonderful job of simplifying the user experience in their interface. Unfortunately, the same cannot be said of some of their other decisions.
    As you point out, the functionality required to access a set of files on a flash drive would be a simple, elegant solution to your problem. That, however, would run counter to Apple's philosophy that (a) you shouldn't be looking at files; your apps should handle that, and (b) USB connectivity is so old fashioned compared to the (not available for the iPad) delights of Apple's new proprietary physical connection. (Thunderbird, Thunderclap, I can't recall.)
    The Galaxy handles your problem (apparently with an adapter.) Other tablets, e.g. the about to be released ThinkPad Tablet, handles the problem without an adapter.
    BTW, I'll just share one caution with you. I've tested various PDF reader/annotation solutions on the iPad. While several options work quite well depending on requirements, it's worth noting that while reading poses few challenges, annotation can be very challenging on such a small screen. Keep it in mind if you need that capability.
    iPad Junkie!
    14875
    Sep 2010
    Kansas
    116
    Maybe look in to the Toshiba Thrive? full size usb, mini usb, full size hdmi and full size SD card slot running android 3.1.
  1. I bought 2 screen protectors - help me decide which one to use
    By GAMESHARQ in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-28-2011, 09:22 AM
  2. How quickly you decide buying an app?
    By mobi1 in forum iPad General Discussions
    Last Post: 05-03-2011, 08:21 PM
  3. I'm still trying to decide
    By BebopDesigner in forum iPad General Discussions
    Last Post: 10-05-2010, 06:16 AM
  4. Need help, cant decide...
    By ahmerkhan in forum iPad General Discussions
    Last Post: 06-10-2010, 12:35 AM
  5. WiFi Only vs. 3G: How to Decide
    By stevenflaugher in forum iPad General Discussions
    Last Post: 03-25-2010, 03:13 PM
adaptor for flash drive to ipad2
can i store my flash drive to ipad2
flash drive adapter for ipad2
how do i get pdf files from thumb drive to ipad2
how to save file thumbdrive galaxy ipad
ipad 2 useless without usb drive
ipad 3 write save documents usb how?
read video files from a flash thumbdrive on ipad
tiod
trying to decide if i want to get an ipad
