ipad 2 camera; sometimes it doesn't work
This is a discussion on ipad 2 camera; sometimes it doesn't work within the iPad 2 Forum forums, part of the Apple iPad Discussions category; i did a search on the web and couldn't find anything about it so maybe i'm doing something wrong or perhaps i have a defective ...
Results 1 to 9 of 9
    58222
    May 2011
    hawaii
    29
    i did a search on the web and couldn't find anything about it so maybe i'm doing something wrong or perhaps i have a defective ipad. this is what happens.
    when i click on the camera icon, the camera function turns on. so far, so good. however, when i try to take a picture by clicking on the "button", nothing happens! i press and press and nothing. i wait for about 20 seconds and then i press and it clicks; picture taken. but sometimes even after that, i'll press and nothing happens. it's driving me nuts.
    i don't know why it sometimes takes a picture and why it sometimes doesn't.
    if you guys have any ideas, please let me know before it drives me nuts!
    thanks.
    119 times
    15,248
    58222
    May 2011
    hawaii
    29
    thanks for the quick and very clear instructions! i tried the first method and the camera seems to work as it should now but i'll try it for the next couple of days and post again; with any luck, your solution is all that's needed. thank you!
    119 times
    15,248
    OK - pleased to hear - but don't hesitate to get back in touch with us if there's any more trouble - that's what we're here for!!
    58222
    May 2011
    hawaii
    29
    jeez! have you been nominated for sainthood yet?!? thanks for being so helpful!!! i really do appreciate it!
    58222
    May 2011
    hawaii
    29
    i thought so. guess what? i accidentally figured out why i was having problems. and it comes down to one simple thing: my finger was often on the screen while trying to take a shot. THAT was the problem! don't know if anyone else will be helped by this but i hope so!
    125382
    Nov 2011
    Cyprus
    10
    As someone who is very very new to iPad, and only have a Dell computer, not a Mac - what exactly IS the Power button? My camera worked for about a month, but now, all I get on the camera is a blank black screen - no comtrols at all. Why?
    183154
    Mar 2012
    Oakville
    Thanks Tim for great advice on how to fix the camera. It worked right away!
    179010
    21 times
    Mar 2012
    552
    FAIL: I sometimes take pics with my fingers over the camera lens lol I do it every time and never learn haha
    Also another good tip is to hit the volume up button on the side and it also takes the picture.....
  1. Popup windows javascript doesn't work on ipad
    By wgm51 in forum iPad Help
    Last Post: 06-02-2011, 12:11 AM
  2. youtube doesn't work in Ipad
    By jacppe in forum iPad General Discussions
    Last Post: 01-23-2011, 10:32 AM
  3. Winterboard doesn't work on my Ipad - Boot loop
    By Fuzedmind in forum iPad Hacking
    Last Post: 01-10-2011, 11:59 AM
  4. Why doesn't my map work?
    By W4KRR in forum iPad Help
    Last Post: 12-26-2010, 09:15 AM
  5. Podcast Download from iPad doesn't work?
    By ljholland in forum iPad Help
    Last Post: 12-05-2010, 06:46 AM
how do you take a picture the button won't work on the ipad
i pad camera doesn't work
ipad 2 back camera doesn't work
ipad camera does not work
ipad camera doesn't work
video function on ipad doesn't work
why doesn't my flash work on my ipad mini camera?
why ipad camera wont take picture
