Howm to use EVDO on iPAD2
This is a discussion on Howm to use EVDO on iPAD2 within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi Everyone. I have just bought iPAD2 and i want to use EVDO on it. I am using iPAD in Pakistan and there is just ...
Results 1 to 5 of 5
    70776
    Jun 2011
    Hi Everyone. I have just bought iPAD2 and i want to use EVDO on it. I am using iPAD in Pakistan and there is just one operator providing EVDO services. However, they give in their PCMSI slot card or USB to use this service. Is there any way I can use this service with my iPAD2
    37165
    2 times
    Minnesota
    374
    EVDO on iPad2
    I have a Mi-Fi wireless router (Verizon). It works well. There are no apps that let you use the camera USB adapter for other than transferring photos. Other data transfer does not work. As for PCMCIA interface devices ... ipad2 does not have one nor interface with one.
    Therefore, at this time your desire to use USB or PCMCIA interface connections is not possible.
    You are forced to use WiFi and of course you must be within range of the sending device... so it doesn't give you cell phone connect anywhere.
    70776
    Jun 2011
    Smile
    Thanx.
    However, coming back to the original question, how should i use EVDO on iPAD then? Should i use a sim card?
    61094
    6 times
    Jun 2011
    271
    As I understand it EVDO is a form of CDMA so if that is correct you can't natively connect an iPad to an EVDO network. I'm assuming that in Pakistan iPads are like everywhere except the USA and only available as wifi or wifi+3G. I guess what you would have to do is get an external device that would connect to the EVDO signal then transmit it to the iPad via wifi (act as a router in other words).
    70776
    Jun 2011
    Thanx
    However, i have seen EVDO been used in U.A.E on iPAD2 without wifi. So do we need a sim?
    And yes, EVDO is CDMA.
  1. How to know if iPad has EVDO or HSDPA
    By mynd in forum iPad General Discussions
    Last Post: 04-01-2011, 10:55 AM
data sims for ipad in pakstan
evdo for ipad
evdo ipad
how set evdo at ipad
how to use evdo on ipad
how to use ipad 3g in pakistan
ipad 4 evdo
ipad and evdo
ipad evdo
using ipad evdo
Tags for this Thread
