Problems charging ipad2 when in universal docking station
This is a discussion on Problems charging ipad2 when in universal docking station within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Let me know how it goes - I simply *hate* to be defeated on solving a problem.... Thanks for your patience.... Tim...
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    116 times
    15,249
  3. #12
    7489
    126 times
    Jun 2010
    Sacramento, California
    14,962
    This is true, babe, this is true.
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
  4. #13
    579 times
    Dayton, WA
    13,189
    I'll throw in my two cents, and in this case that's about what it's worth. Is the iPad in a case that might prevent it from seating fully?
  5. #14
    iPad Enthusiast!
    44656
    Sydney
    52
    Case interference is more than likely!
    I had to snip a bit of a slice off the connector hole to allow the iPad connector to seat properly and thus charge effectively, there was a small overhang of leather preventing the correct mating of the two devices.
    My "INCASE" exceptional in all other ways, needed a minor operation, and survived without further problem.
  6. #15
    211248
    May 2012
    Manchester
    Fix
    Quote Originally Posted by fitzpatrick2362 View Post
    its as far in as it will go so i am stumped myself.
    I will contact the seller t see of similar problems.
    If not it will be geting returned.
    Thanks for taking the time to help.
    Hey
    I recently purchaced the same dock off Amazon. I also experienced the problem you described and went to this site. Having knowledge of electronics I dismantled the dock and using test equipment I found a solution for u you. At the iPad end of the circuit board there is asurface mount resistor. I took out this resistor with a solering ironand tested it. The cable that came with the dock I also descovered had birnt out and subsequently kept earthing itself. Having disconnected the resistor (and not resoldering the circuit creating a break) this solved the iPad charging sound problem and also the charging problem. Basicly the dock is fine its the 'fake' cable that came with it thatis a piece of s**t.
    Hope this helps
  1. Charging problems.
    By ashley69 in forum iPad General Discussions
    Last Post: 10-21-2011, 02:39 PM
  2. Charging Problems
    By Remi in forum iPad Help
    Last Post: 02-10-2011, 12:23 AM
  3. Docking station
    By acstewart08 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 01-12-2011, 03:56 PM
  4. keyboard docking station question
    By Heaviside in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 11-04-2010, 05:52 PM
can you charge an ipad on a laptop docking station?
common ipad problem of the charger not charging
ilive docking station not charging ipad
ipad beeping while charging
ipad beeps when charging
ipad dock cant charge
ipad logitech docking station not charging
ipad won't charge in docking station
ipad won't charge on dock
ipad wont charge on dock
troubleshooting formemorex docking station for ipad
why won't my logitech docking station charge my ipad
