Does the backlight bleeding eventually go away?
This is a discussion on Does the backlight bleeding eventually go away? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Morning all. I just got the white iPad 2 on Monday, and when I first got home and got it turned on, one of the ...
Results 1 to 10 of 16
    60836
    May 2011
    Sunny FLA
    13
    Morning all. I just got the white iPad 2 on Monday, and when I first got home and got it turned on, one of the first things I looked for was the bleeding. I saw that mine had a little bit of it, not too noticeable, on the bottom right corner. I got my iPad from Best Buy, so I'm not sure if they will exchange it (if needed), and there is no Apple Store near me.
    So, I'm wondering will the bleeding go away, or do I need to see about a replacement?
    Banned
    48444
    Wales
    667
    Quote Originally Posted by Nolegirl
    It won't go away no, but if you hardly notice it then I guess it's up to you whether you can live with it or not. Apple will replace it if you are not happy with it
    116 times
    15,249
    In the early days of the iPad2 there were 'rumours' that it get better after a time but that now seems not to be the case. The thought in the early days was that the problem was due to the adhesive that was used to attach the screen of the iPad2 not having dried ('cured') properly and that this would improve over time. But I've not heard of anyone whose iPad screen bleeding has got better - most folks who have had a problem have simply returned it for another unit. But, if you've looked through the Forum, you'll have seen that several Members have had to take even those replacement units back.
    You'll have seen, too, in the Forum that Apple have now sourced an alternate screen supplier (they had two suppliers originally and it seems as though the bleeding screens were from one of those suppliers only) and so the problem should be getting better.
    Given that your iPad is under warranty for a time yet, you might want to consider waiting for a while so that you can have a better chance, when and if you return it, of not ending up with a unit with a similar problem.
    Hope it all works out OK for you and let us know how you get on.
    39127
    4 times
    just outside of philly pa USA
    347
    It will not get better and you only have 14 days to return it to best buy but apple will cover it up to one yr
    from USA bucks county pa Sent from my iPad using iPF
    53837
    May 2011
    Manila, Philippines
    71
    Hey guys! It so happen that I stumbled into this thread that made me curious to check if my iPad 2 has the same bleeding issue. Sadly, i do. Is the bleeding a big issue? I was hoping that AAPL wiil address this issue immediately.
    Btw, got my iPad 2 in the Philippines a month ago. Should i go back to the store and ask for replacement?
    50431
    May 2011
    Toronto
    25
    I have the so called light bleeding on my iPad 2 but its only noticeable in a complete dark room with the screen completely black. It's not enough for me to return mine. I also noticed it slightly on my PlayBook when its booting up on the dark screen. Using both of them day to day I don't even notice it. It completely depends on how much it bothers you. But from reading numerous posts on the web some people have gone through a bunch with the same issue even going back as far as the iPad 1.
    53837
    May 2011
    Manila, Philippines
    71
    Quote Originally Posted by Hup55
    I just hope that Steve Jobs will address this issue once and for all to ease every iPad owner's worries...Thanks!
    61570
    Jun 2011
    La mirada Ca
    6
    yea the bleeding is pretty weak... getting bummed really quick that apple is becoming more and more focused on releasing a new product rather that making sure it is ready to market...
    39199
    2 times
    173
    Nolegirl, I just got my iPad 2 from Bestbuy as well on Sunday. Mine had bleeding, so I took it back back for a replacement, thay had no issues returning it. My replacement has the bleeding as well, but not as severe as my 1st one. As has been said if you can live with it, then it's not going to hurt anyting. I can only see mine in a very dark room with an almost black screen, other than that I don't even notice it.
    Banned
    48444
    Wales
    667
    Taking luck out of the equation, am I the only person whose iPad has no bleeding at all? Still seems a predominately US issue.
  1. Who has Backlight bleeding?
    By donka in forum Apple iPad Polls
    Last Post: 10-08-2011, 03:47 PM
  2. Backlight bleeding?
    By JayCin81 in forum iPad 2 Forum
    Last Post: 05-13-2011, 03:02 PM
  3. LCD backlight bleeding?
    By Stefx in forum iPad 2 Forum
    Last Post: 03-14-2011, 06:01 PM
backlight bleeding playbook
can backlight bleeding go away
does backlight bleed go away
does backlight bleeding go away
does light bleed go away
does screen bleed go away
how does backlight bleed happen
how does backlight bleeding happen
how does backlight bleeding happen?
playbook backlight bleeding
why does backlight bleeding go away
will backlight bleeding go away
