Ipad 2 won't start and keep rebooting
This is a discussion on Ipad 2 won't start and keep rebooting within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have an iPad 2 64 Gb 3G White. I was using Safary and the iPad froze on me. After couple of minutes the only ...
Results 1 to 10 of 10
    61185
    Jun 2011
    5
    I have an iPad 2 64 Gb 3G White. I was using Safary and the iPad froze on me. After couple of minutes the only thing I was able to do was resetting it. Problem is that after resetting the iPad won't restart. It shows the apple icon for few seconds than screen blinks, go black and apple icon comes back again. it keeps in this loop and wont restart.
    Anyone else had or have this problem?
    Any recommendation?
    iPad Enthusiast!
    56006
    May 2011
    Iowa
    87
    Did you try connecting it to iTunes and restoring it? If that doesn't work, you may need to take it to an apple store and see what they can do. They might be able to fix the problem, or it may be defective and they'll switch it out with a new one. Taking it to a store is your best bet if the restore doesn't work.
    Do you get any error icons like a face or an 'X'?
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    It's quite unusual for a device to get into a rebooting loop like that. I'm afraid the only thing you can do is restore it using iTunes if another reset does not stop it looping.
    In order to do this, you may need to put the device into DFU mode. This is quite simple and I have written a guide on it in the link below. DFU mode will prevent it constantly rebooting and allow iTunes to recognise the iPad and restore it.
    DFU Mode for Dummies
    iTunes will prompt you that it has found a device in recovery mode and you should restore it. The only option available will be to press the "restore" button. This will download a fresh firmware from Apple and restore your iPad to factory new state. Once this process completes you will get the choice to set up the iPad as "new" or restore from a previous backup. If you recently synced with iTunes and want to have your iPad set back up with your data and apps / music / etc., you should choose the second option. Otherwiese, if you choose "new" you will have to manually put all your apps etc back on the iPad manually and provide settings for all your apps again.
    Hope that helps.
    Last edited by f4780y; 06-01-2011 at 05:57 PM. Reason: underlined the important statement
    577 times
    Dayton, WA
    13,177
    Before going t0o far, lets make sure you did the reset properly, or at least try it again.
    Hold down the power and home button at the same time until the Apple logo appears. Be patient, it might take more than a few seconds, at least 7 for the reboot to happen, twice that or more before the logo actually appears.
    Banned
    48444
    Wales
    667
    Just another quick idea. Before you restore your iPad, make a physical ( DVD ) copy of all your apps and data, might take a few DVDs but just in case you can then restore the backup to iTunes a fail safe if you like!
    61185
    Jun 2011
    5
    Quote Originally Posted by f4780y View Post
    Hope that helps.
    I followed your DFU mode instructions and restored firmware and personal data. Seems to be working fine now.
    Thanks for your help!
    61185
    Jun 2011
    5
    Quote Originally Posted by china_cat84 View Post
    After connecting to ITunes and restoring it my iPad came back to life. Tks!
    61185
    Jun 2011
    5
    Connecting to iTunes and restoring it did the trick. Tks.
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Quote Originally Posted by LeoR
    Very Welcome. Really glad to hear it worked for you.
    61185
    Jun 2011
    5
    Yes, resetnwas done correctly. Restoring solve the problem. Tks
  1. IPad won't start
    By Iguanaroar in forum iPad Help
    Last Post: 06-25-2012, 04:12 PM
  2. ipad rebooting again and again
    By GSheridan in forum iPad Help
    Last Post: 08-02-2011, 02:12 PM
  3. Jailbroken iPad (4.2.1) not rebooting after battery drain
    By radumarinescu in forum iPad Hacking
    Last Post: 06-17-2011, 09:59 AM
  4. Just got an ipad! Need help to start up!
    By foxtrot in forum iPad Help
    Last Post: 07-20-2010, 09:22 AM
  5. Replies: 3
    Last Post: 05-11-2010, 05:46 AM
ipad 2 black keeps restarting
ipad 2 keep restarting
ipad 2 keeps rebooting
ipad 2 reboot loop
ipad 2 reboot loop fix
ipad keep restarting
ipad keeps rebooting
ipad keeps resetting
ipad reboot loop
ipad restart loop
my ipad keeps rebooting
restarting ipad loop
