Locked myself out of my own wifi and can't get back in!!! Was asking for a password but didn't know it and now it is just telling me I am unable to join?
This is a discussion on Locked out of my own wifi??? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Locked myself out of my own wifi and can't get back in!!! Was asking for a password but didn't know it and now it is ...
Your password might on the side of router then you go to setting on iPad go to wifi and press forget this wifi then rejoin with the pass word from router
from USA bucks county pa Sent from my iPad using iPF
I tried that! The strange thing is that I can be connected using another persons network but when looking at the IP address it is the same as mine? Could I have two networks or has someone taken my info and made their own? My network is locked but this one isn't!
Are you locked out of your WIFI, meaning you don't have the encryption password, or are you locked out of your router? If you can get into your router, then just change the encryption key password for the network there and you should be good to go.![]()
Had same problem, just reset your router. You can do that by cutting the power, count to ten then plug it back in again. Should work fine after that
The IP address that you are probably seeing is a so-called Private IP address and usually has the form 192.168.x.y. The router performs Network Address Translation (NAT) from the Internet to all the devices on your home network. Although each router will have a separate IP address, it will translate that to a Private IP address of the above form so, yes, you'll see IP addresses like this on most home or WiFi networks. No need to worry!!
Thanks everyone!!! I contacted Motorola and a wonderful agent helped me! Harelyman and Tim, you guys were right on :-)
Can't help much in the technical department but if any of you need help in wine, let me know!
This is such a great resource!!!!
Glad to here your all fixed up with the wifi
