External speaker
This is a discussion on External speaker within the iPad 2 Forum forums, part of the Apple iPad Discussions category; For some reason the only way I can listen to the iPod on my iPad 2 is through headphones. It says it is in headphone ...
Results 1 to 6 of 6
    58839
    May 2011
    External speaker
    For some reason the only way I can listen to the iPod on my iPad 2 is through headphones. It says it is in headphone mode and it switched that way by it self. I want to use the external speaker but I can't figure out how to switch it back. Please help!
    116 times
    15,249
    Quote Originally Posted by melbo13 View Post
    There are several possibilities here. First of all, the volume control on the iPad 'remembers' the volume separately for the headphones and the iPad speaker - so if you've got the headphones turned all the way up and unplug them, you might not hear anything if the speaker was previously turned all the way down.
    You say you want to use the 'external speaker' and I wasn't 100% sure what you meant by that. Do you, in fact, mean the 'internal' iPad speaker? If so, OK, check to see after you've unplugged the headphones that the volume is turned up again.
    If you actually meant an 'external' speaker - i.e. you've connected a remote external speaker via a cable to the iPad, then the problem might not be in the iPad itself and, of course, you would need an amplifier. The audio circuitry in the iPad is not capable of directly powering a full-size external speaker.
    Another possible solution - if you really meant the iPad's internal speaker - is to perform a complete iPad power-down, by pressing and holding the Power button until the slider control appears and then accepting the offer to power down. Once the iPad screen is completely blank you can press and hold the Power button again until the white Apple logo appears. After a few seconds the iPad will have powered up. This process clears quite a few unexplained 'issues'.
    I hope one of these ideas works but, if not, get back to us and we'll suggest some more.
    Good Luck
    58839
    May 2011
    You were right, I did mean the internal speaker. I tried what you said. I powered down Nd then back up. It didn't fix it. What is so strange is that I had not used headphones when this happened. Only after this happened did I use headphones because I couldn't hear anything. I checked sounds under general setting and the internal speaker works there. I dont know where else to check.
    116 times
    15,249
    Are you doing this with the iPad plugged in to the dock connector? There are several issues....
    If it's plugged in to the charger - remove the charger cable and try again - we've had reports of faulty charger cables that 'tell' the iPad that it's plugged in to the dock instead and therefore connector to an external speaker.
    If it is connected to the dock stand, try unplugging it and try again...the dock connector stand is intended to connect the iPad to external speakers, so the internal speaker is disabled.
    56065
    May 2011
    UK
    20
    I have just tested mine, playing through the internal speaker and it works fine.
    40526
    14
    Try restoring it in iTunes that will usually fix any problems and if not take it back to apple
    Sent from my iPad 2 using iPF
  1. iPad 2 only produces music to left external speaker
    By TitanJeff in forum iPad Help
    Last Post: 06-15-2011, 08:59 AM
  2. Iclarity speaker
    By ATC2 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-12-2011, 07:11 AM
  3. Speaker Question
    By druusilla in forum iPad 2 Forum
    Last Post: 04-18-2011, 11:47 PM
  4. iPad 2 speaker
    By Fifi1992 in forum iPad 2 Forum
    Last Post: 03-06-2011, 05:31 PM
  5. Speaker systems?
    By DM51 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 08-24-2010, 03:22 PM
can i still hear using headphones on ipod when external speakers not working
how do i get a speaker for my ipad
how to connect ipad to external speakers
how to disable speaker ob iphone and turn on headphone mode
how to switch off headphone mode on ipad
how to turn ipad offf of headphone mode
how to turn off headphone mode on ipad
ipad 2 external speaker not working
ipad external speaker cable
ipad external speakers not working
turn off ipad speakers
turn on external speakers to ipad with headphones in
