Use the Smart Cover with a Gel Case
This is a discussion on Use the Smart Cover with a Gel Case within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi everyone; As I'm sure some of you by now are cursing the fact that you bought a real nice Gel protective cover for your ...
Results 1 to 1 of 1
    49611
    7
    Hi everyone;
    As I'm sure some of you by now are cursing the fact that you bought a real nice Gel protective cover for your iPad 2 only to discover it doesn't work well with the Apples Smart Cover. Well, here's a nifty "fix" for that, and I hope it will save you from throwing out either the Smart Cover or the Gel protective case.
    First, install the Gel cover and peel back the top edge, just enought to allow the Smart Cover to "install". Then, with a fine marker (Sharpie works great here), mark where the edges of the Smart Cover hinges come to.
    Next, cut down the top of the Gel cover at that mark on both ends and then cut along the outside, or bottom "line" on the Gel cover all the way to the other end.
    Here's a photo that should help with the directions. Once you've done this the Smart Cover works beautifully with the Gel cover.
    I hope this is of some help to some, and to whomever is responsible for this forum, thank you for a great place to learn all about the iPad 2. I really appreciate it.
    Bud
  1. Best case compatible with Smart Cover
    By Westec in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-27-2011, 04:37 AM
  2. Do you think the smart cover is the best case for ipad 2?
    By Tapmyapple in forum iPad 2 Forum
    Last Post: 06-19-2011, 12:44 AM
  3. Best Smart Cover Alternative 360° Case?
    By DCYPHAx in forum iPad 2 Forum
    Last Post: 04-21-2011, 08:56 AM
  4. Smart Cover with back case!?
    By UNC_Buccaneer in forum iPad 2 Forum
    Last Post: 04-19-2011, 07:06 AM
can i still use a smart cover if i use xo cover skins
can i use a gel case with a smart cover on ipad
can i use a gel case with the ipad smart cover
can i use a gel skin with ipad smart
can you use gel skins with smart cover for ipad 2?
gel cases with smart cover
ipad 2 gel case smart cover compatible
ipad 2 gel case that works with smart cover
ipad 2 smart cover and gel case
ipad gek case compatible with smart cover
ipad gel cases use with smart cover
jelly case smart cover ipad2
