Results 1 to 10 of 14
    38682
    Connecticut
    8
    Question about cellular operation on the iPad 2
    I just signed up for the Verizon 2GB cellular service.
    Q1: does the iPad automatically switch to WiFi when using the WiFi system in my home or do I have to go and select it under the WiFi settings?
    Q2: Verizon assigned me a 10 digit phone number. What is this used for? Is it to contact Verizon or a phone number assigned to me to use?
    20742
    Nov 2010
    Quebec City
    22
    Good question, I'm interested in the answer too as I am soon embarking on a European tour.
    624 times
    Dayton, WA
    13,312
    You will need to go to the Wi-Fi settings and select your home network the first time. The iPad will automatically detect and use Wi-Fi networks that you've used before, and when it is connected it will use them instead of 3G. In some circumstances you may manually remove your home networks settings, or they may get lost some other way. In that case you will just reconnect again.
    If you have the Ask to Join option on, then anytime you are near a new network (and not already connected) the iPad will ask you if you want to join it. I find it annoying, so I leave it off.
    If you see the Wi-Fi icon at the top left of the screen, you are connected to and using a Wi-Fi network. If you see 3G, you are using 3G. Look there if you are in doubt and don't feel like going through settings.
    The phone number is how Verizon identifies your account. Other than communicating with them about your account, there is nothing you can do with it. It won't receive or send calls, SMS, or any of the other typical phone services.
    20742
    Nov 2010
    Quebec City
    22
    Thanks for the thorough response twerppoet!
    Would turning on Airplane mode also keep the iPad from checking for a 3G network?
    624 times
    Dayton, WA
    13,312
    Turning on Airplane mode turns off all the radios, Wi-Fi, cellular, and bluetooth. So, yes, it will prevent the use of 3G, and Wi-Fi too.
    It's called airplane mode because many airlines require you to turn off your cell phone and wireless devices.
    38682
    Connecticut
    8
    Thanks for the update. That's the way I was lead to believe it's suppose to work. However this is the way it actually worked after I signed up for cellular. After the cellular was authorized, I walked far enough from my house to see the Verizon Cellular kick in. Fine so far. When I went back into my house and the same room my router is in, the WiFi didn't pick up. It was still verizon. I went to a site and then looked at usage, it had increased. I had to go into settings and turn off the cellular, and WiFi took over. I, and other people with the iPad 2's have been experiencing WiFi connectivity losses for no reason. There are posts in this forum discussing the issue. No one including Apple seems to have an answer. I'm wondering if it's related to this issue and is why it won't reconnect. I've seen this phenomenon happen at other locations I've been at a where I loose WiFi. It still shows the connected router in the settings but no internet. Some times I have to reboot the iPad to get the WiFi come back. I'm not happy!
    20742
    Nov 2010
    Quebec City
    22
    Quote Originally Posted by anderdea
    Wow! That is good to know. I would describe your issue on the Apple discusion boards to see what type of answer you get. If you do, please post back if you hear anything.
    At the very least, we can hope that this issue is resolved in a future iOS release.
    iPad Enthusiast!
    12114
    Aug 2010
    31
    I can't speak to Verizon, but I have the AT&T 3G/WiFi iPad2, and it works exactly as it should. When I come into WiFi range, it drops 3G and goes WiFi. If I go away, it switches back to 3G. Nothing to do, it just happens automatically. Maybe Verizon does it somehow differently?
    58166
    May 2011
    http://ipad2sale.net/
    11
    Quote Originally Posted by anderdea View Post
    You can use it to call and sms and Verizon use it to recoqnized you
    15304
    Sep 2010
    Vancity
    178
    Verizon might have some sort of setting that doesnt allow the ipad to do it on its own. Why cant you speak with verizon?
    iPad 2 64GB 3G Black,
    iPad 1 64GB 3G,
    iPhone 4 32GB Black,
    iPod 3rd Gen. 32 GB White.
  1. Ipad 2 cellular data
    By Mike-e in forum iPad 2 Forum
    Last Post: 03-30-2011, 07:34 PM
  2. Screen Saver operation
    By Chris Kappmeyer in forum New Member Introductions - Site Assistance
    Last Post: 02-22-2011, 09:20 AM
  3. Replies: 0
    Last Post: 01-14-2011, 02:20 AM
  4. new ipad doesn't have cellular data to add AT&T
    By pam weber in forum iPad General Discussions
    Last Post: 12-22-2010, 01:53 PM
  5. I have a IPad, but there is no operation system
    By liuchang9443 in forum iPad OS
    Last Post: 06-27-2010, 02:35 AM
can i use my ipad with wifi cellular verizon on the airplane
cell service on ipad 2?
cellular service for ipad2
does ipad2 have cellular
how to use cellular service on ipad
ipad 2 cellular
ipad 2 cellular calls
ipad 2 wifi vs cellular
ipad operation questions
ipad2 wifi cellular
ipad2 with wifi and cellular
turning verizon on and off on ipad2
