After enabling multi gestures...
This is a discussion on After enabling multi gestures... within the iPad 2 Forum forums, part of the Apple iPad Discussions category; ... when I closed my cover it didn't go into sleep mode anymore. I found this weird because it always had done so before. I ...
Results 1 to 6 of 6
    iPad Enthusiast!
    57045
    May 2011
    Boston
    48
    ... when I closed my cover it didn't go into sleep mode anymore. I found this weird because it always had done so before. I thought it might have been something with the magnets so I repositioned the iPad but it still wouldn't go into sleep mode. I thought it was an issue with my case which ticked me off. I went into Settings / General and notice a new option. iPad Cover Lock / Unlock was not there before I enabled multi gestures. I found this very odd that the option would just suddenly appear when I did that. I put it to on and sure enough it goes into sleep mode now when the cover is closed. This happen to anyone else? FYI I enabled multi gestures by the adding the two lines method via iBackUpBot.
    56495
    May 2011
    India
    389
    I've had no problems wid enabling multitouch via iipadbot method..
    Sent from my White iPad 2.
    iPad Enthusiast!
    57045
    May 2011
    Boston
    48
    Quote Originally Posted by iRuthlessPad View Post
    Didn't have any problem per say it worked like a charm but just found it unusual that the option just appeared after I did that. Was it hiding?..lol
    56495
    May 2011
    India
    389
    Dude that option is there from the start..those two lines u add for multitask dont do anything to ipad except enabling the gestures..i guess u never saw that option before in ur ipad...thats why u shud always read the manual its available free on ibooks..
    Btw multitouch gestures are Awesome! And this method of adding 2 lines is way more easy than downloading a 4 gig program
    iPad Guru
    30446
    12 times
    3,196
    The option iPad Cover Lock/Unlock only appears after the first time you have used the cover. If you went to the settings before using the cover for the first time, there would have been no option for iPad Cover Lock/Unlock, as Apple hides the option be default, in case you don't use the SmartCover.
    iPad Enthusiast!
    57045
    May 2011
    Boston
    48
    I guess I just never noticed it after I put my iPad in it's new case..lol
    I couldn't find that darn file to modify with iBackUpBot at first so I started the alternate way. Being a Windows guy I saw you had to load a VM to get OSX running so you could then run Xcode, etc etc. I went back to iBackUpBot and looked at it line by line and finally found that springboard.plist file. I love multitouch gestures also... just the fact you really don't have to touch the home button anymore makes it worth it. I have been reading though that for some people adding those lines still doesn't enable it. Now if they will just come out with a jailbreak for the iPad2 I'll be a happy camper..lol
  1. Enabling "Secret" Multitasking Gestures on the iPad 1
    By richsadams in forum iPad 1 Forum
    Last Post: 11-10-2011, 02:11 PM
  2. Enable multi-touch gestures on Windows, no jailbreak request
    By KingKoala in forum iPad General Discussions
    Last Post: 10-13-2011, 04:42 AM
  3. Multi gestures driving me nuts
    By Ipadgk in forum iPad 2 Forum
    Last Post: 04-30-2011, 11:21 PM
  4. Enabling multi-gestures
    By totemynote in forum iPad 2 Forum
    Last Post: 04-15-2011, 06:37 PM
  5. Replies: 4
    Last Post: 03-17-2011, 05:13 AM
how to unlock ipad 2 in gesture mode
ipad 2 gestures lock gestures
ipad gesture lock
ipad lock gesture
ipad sleep gesture
ipad smart cover suddenly doesn't lock
multi gestures ipad 2
multigesture on ipad2
