data usage
This is a discussion on data usage within the iPad 2 Forum forums, part of the Apple iPad Discussions category; i have a problem. i have an at&t 3g ipad2. im using tunein to strem music to my cars stereo thru the 3.5 jack. when ...
Results 1 to 7 of 7
Thread: data usage
    54870
    May 2011
    51
    data usage
    i have a problem. i have an at&t 3g ipad2. im using tunein to strem music to my cars stereo thru the 3.5 jack. when a call comes in to my bluetooth phone, the car mutes the music and activates the bluetooth call. very cool. but, i found the hard way, that the music i still being streamed to my ipad, even if i dont hear it in the speakers. when the phone call is done, the music from the pad immidiatly continues on the cars stereo. does any on know of a way to stop the music streaming on the pad, when a call comes into my sprint phone? thanks
    116 times
    15,249
    It is difficult to see how this could be achieved because the iPad is 'unaware' of the incoming call, since the only connection between your car - where the call is being received - and the iPad is the headphone jack connection. Plus, TuneIn is constantly recording the incoming music on its 30 minute storage buffer (or you might even have set it to record continuously) in case you wanted to listen to a particular favourite track that happened to be playing when the call came in.
    So, in my view, this is simply not possible. To prevent TuneIn from streaming when you receive the call, you'd have to manually pause the iPad from playing - most definitely not recommended while you're driving.
    54870
    May 2011
    51
    thanks Tim , if you can think of other way/app to stream music and stop when needed, lemma know. thanks
    15304
    Sep 2010
    Vancity
    178
    Do you have an aftermarket deck or is it stock?
    iPad 2 64GB 3G Black,
    iPad 1 64GB 3G,
    iPhone 4 32GB Black,
    iPod 3rd Gen. 32 GB White.
    54870
    May 2011
    51
    no deck, just 3.5mm cable
    15304
    Sep 2010
    Vancity
    178
    Well in that case, I dont think you have any options. As Tim said, the unit isnt able to tell that youve received a call so it continues to play since the 3.5mm jack is still in the headphone jack. If you had an aftermarket deck, you could just buy and iPod wire that connects to the back of your deck. With this the deck will recognize when it is switch sources and will automaticall pause the ipad until your done your call.
    iPad 1 64GB 3G,
    54870
    May 2011
    51
    Quote Originally Posted by King.Khoja View Post
    interesting... where can i find such an after market dock?
  1. Please explain about data usage
    By maryinredding in forum iPad Carriers
    Last Post: 07-04-2010, 10:02 PM
  2. Two months now -- how much data usage?
    By Pingles in forum iPad Carriers
    Last Post: 07-02-2010, 05:51 PM
  3. Data Usage
    By 60DegreeVVT in forum iPad Carriers
    Last Post: 06-09-2010, 01:21 AM
  4. Data usage
    By FirstApple in forum iPad Carriers
    Last Post: 06-07-2010, 06:34 AM
  5. 3G Data Usage Heads Up...
    By Edlex in forum iPad General Discussions
    Last Post: 05-14-2010, 04:07 AM
how is data use calculated for ipad
how to calculate data usage on ipad
how to calculate data usage on ipad answers
how to figure out data usage on ipad 2
how to find out how much data used on ipad
how to measure data usage on an ipad
how to track data usage on ipad 2
ipad data usage - how calculated?
ipad measure data usage
measuring data usage ipad
typical data usage ipad
