ipad 2's Smart Cover burn-like stain on the magnet
This is a discussion on ipad 2's Smart Cover burn-like stain on the magnet within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I just noticed that when I pull out the Smart Cover from the ipad 2, there is like a burn stain on my ipad's left ...
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 34
    53711
    May 2011
    Philippines
    12
    I just noticed that when I pull out the Smart Cover from the ipad 2, there is like a burn stain on my ipad's left side when smart cover is connected. To my surprise, it actually came from the more stain of the magnet of the smart cover???? How is that possible??? My theory is that it might be when i charge my ipad 2 and the outlet where our electricity is flowing is kind of like having problems. Because sometimes when I am about to charge my ipad 2, there is a spark-like on the outlet.... Do you think it could be the reason why did i notice the brown burn like stain on both the side of my ipad 2 and the magnet of the smart cover???? please help me
    31266
    2 times
    Coral Springs Florida
    133
    If there is a spark coming in from the outlet, change the outlet and or have an electrician look at it. Simple bit of advice....don't plug anything into an outlet that sparks every time you plug something in. As far as the burn stain on the iPad/smart cover anything is possible.
    53711
    May 2011
    Philippines
    12
    Quote Originally Posted by laserguy007 View Post
    Thank you my friend. But what else could possibly be the reason why did it have that stain??? It's colored brown, it's kinda disturbing to look at on our new ipad 2, and when you see the smart cover, kind of frustrating that it could stain the ipad like that...
    31266
    2 times
    133
    No your absolutely right, I would be upset to. Try using some rubbing alcohol and rub lightly. Remember that metal is a conductor and either the ground to the outlet is bad, the wire for the ground is not connected and thats what's causing the burn. Have an electrician look at it or do it yourself. It's actually really easy.
    55826
    3 times
    May 2011
    54
    Quote Originally Posted by pudongski
    I had the same problem. I noticed my cover had a small crack in the plastic on the iPad side of the hinge that attached to the iPad. This is where the stain was coming from. It was a carbon-like stain that did come off after working it awhile with rubbing alcohol. The mark appeared after owning it for a couple of weeks. I took the cover back to Best Buy and got a new one and have had this one for a couple of weeks. Well, this one is also giving the same carbon-like burn mark with no cracks in the plastic. Is this some sort of defect that Apple needs to address? Is anyone else experiencing this?
    53711
    May 2011
    Philippines
    12
    Quote Originally Posted by whodaman View Post
    So if this also happens to you, this might be a defect that surely needs to be addressed. No we're two who have experienced it. However on the 2nd time situation, did it also wear off after rubbing alcohol? Thank you.
    55826
    3 times
    May 2011
    54
    To tell the truth, I didn't noticed the second one did it until I checked today after reading your post. I'm gonna try cleaning it this evening. I'll let you know once I try it.
    55826
    3 times
    May 2011
    54
    Rubbing alcohol worked to clean the side of the iPad but not the smart cover.
    53711
    May 2011
    Philippines
    12
    Unhappy
    It was not removed by rubbing alcohol i guess it will stay there on my smart cover and the stain on my ipad
    7489
    132 times
    Jun 2010
    Sacramento, California
    14,940
    I didn't read your entire thread so if this was stated already sorry ~ but what color is your smart cover?
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
  1. can you use smart cover on ipad 1?
    By mikeos in forum iPad General Discussions
    Last Post: 06-29-2011, 06:55 PM
  2. iPad 2 smart cover is too expensive
    By rishi85 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-17-2011, 05:55 AM
  3. Full iPad 2 Protection With Smart Cap + Smart Cover
    Last Post: 05-15-2011, 10:23 AM
  4. White Ipad Smart Cover
    By JaiDineshable in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-30-2011, 07:27 PM
  5. Replies: 11
    Last Post: 03-14-2011, 08:15 AM
cleaning stains in back of ipad
corrosion on ipad cover magnet
discoloration on one side of ipad
how do you clean ipad 2 magnet cover both sides
ipad 2 cover rust
ipad smart cover discoloration
magnetic ipad cover discoloration
magnets discolor ipad
