best handbrake preset for ipad 2
This is a discussion on best handbrake preset for ipad 2 within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello. What handbrake preset can you recommend to use for ipad 2? I can't find clear answer to this simple(?) question....
Results 1 to 10 of 17
    52818
    May 2011
    5
    Hello.
    29345
    55 times
    Penarth, Wales, UK
    1,996
    iPad
    52818
    May 2011
    5
    Ok.
    15304
    Sep 2010
    Vancity
    178
    Ive used apple tv for a few of my videos, they turned out pretty well. Try that
    iPad 2 64GB 3G Black,
    iPad 1 64GB 3G,
    iPhone 4 32GB Black,
    iPod 3rd Gen. 32 GB White.
    6858
    Jun 2010
    Canada
    291
    Quote Originally Posted by sjleworthy View Post
    iPad
    Yep
    Same resolution as iPad 1
    143209
    Dec 2011
    US
    Quote Originally Posted by din_vl View Post
    Hello.
    Hey friend, there is very simple solution of your problem. you can perform HandBrake download, even you are with any version of iPad, this will helpful for all. this will convert the video file as you want.
    102366
    6 times
    Sep 2011
    Edinburgh
    58
    Buy AVPlayer HD from the app store which plays most formats and no need to convert files at all. Unless your video is in a very rare format indeed this should save you hours of wasted conversion time.
    Banned
    2120
    Apr 2010
    183
    Apple TV or iPad, both are OK.
    Actually if you searched in this forum, you could find the answer: Handbrake Presets for iPhone 4 and iPad
    192310
    Apr 2012
    Southwest
    Hello.
    After many attempts over the last couple of years these are my settings to achieve the best standard def DVD quality for an HDTV and for the iPad 2.
    1st - Click on the Regular 'High Profile' preset. You'll change some of the settings, but this is a good starting point. Now for the step by step setting adjustments.
    I Always make the extension MP4. I don't use mkv.
    PICTURE: Source=720x480. Anamorphic=Strict (this keeps the original screen shape, letter box, 16:9, 3:4). Cropping=Automatic.
    VIDEO FILTERS: Detelicine=Default. Decomb=Default. Delinterlace=Off. Denoise=Off. Deblock=all the way to the left (On).
    VIDEO: Video Codec=H.264 (x264). Framerate (FPS)=Same as source. Variable Framerate-Constant Quality=RF:20.
    AUDIO: To get the best sound output you will need to 'Add Track' 2 sound tracks. In this order add...
    Source=1English (AC3)(5.1 ch), Audio Codec=AC3 Passthru, Mixdown=Automatic, Samplerate=Auto, Bitrate=Auto, DRC=0, Gain(db)=0. This track is for your HDTV to get 5.1 surround sound.
    Then add Source=1English (AC3)(5.1 ch), Audio Codec=AAC (faac), Mixdown=Stereo, Samplerate=Auto, Bitrate=160, DRC=2.5, Gain(db)=0. This track is for your iPad 2. This has to be added or else the movie cannot be loaded onto your iPad 2. I add this last, so it is the top sound output listed.
    SUBTITLES: This setting will vary from DVD to DVD. Usually English or foreign bitmap are the subtitles you want to Add. Is the movie a foreign movie with subtitles throughout? Then you would need to 'Add' the 1.English subtitle. If there are subtitles that only appear during a foreign language part then it usually is 2.English Subtitle. The Forced only, Burned In and Default check boxes are suppose to help figure all this out, but I've experienced variation from DVD to DVD. Forced sometimes works, burned in sometimes works. You may have to play around with these settings. Also the source of the subtitles from the original DVD can be difficult to identify. When you first load the source, you probably will need to Load the video FOLDER, not FILE to get the subtitles to work. Besides trial and error try reading up on subtitle forums for a better explanation. Be sure to remove all subtitles if you don't want any.
    CHAPTERS: I never include chapter marks, it leaves a little white 'chapter x' in the bottom center of the movie.
    ADVANCED: Don't change anything here unless you know what you are doing. All the setting work as is; this is why I clicked on the High Profile preset. To get this tab in particular to be preset for me.
    I don't check any of the 3 boxes on the top. Large file size, web optimized, iPod 5g support. I've only had to check Large file size on home movies that are over 2gb.
    Save these settings as a new Preset. Click on the +Add. Name this new preset. Choose 'Source Maximum' in the drop down tab. Check 'Save Filter Settings'. You can make this new preset your default preset if you'd like.
    File sizes for me are usually between 1gb - 1.5 gb. The largest movies I've converted ended up being 2gb. This is much smaller than the typical 4.7 gb DVD so you can convert many movies and fit hundreds of them on a 500gb - 1tb hard drive.
    Good Luck
    223761
    Jul 2012
    Quote Originally Posted by Tech boo View Post
    I Always make the extension MP4. I don't use mkv....
    I have used your settings successfully to backup DVDs. They work great for me too. I also tried to use them recently for a bluray movie and they actually produced a movie, which I haven't tried yet, but the size of the file is more than 3GB, as opposed to 1GB outputs I get for my DVDs. I suspect it's because of the resolution? Have you tried any settings for blurary movies? Thanks
  1. Safari Multiple Preset Tabs Upon Launch?
    By HTC_EVO_4G in forum iPad Help
    Last Post: 03-14-2011, 10:06 AM
  2. iPAD setting for HandBrake
    By soham100 in forum iPad Help
    Last Post: 12-08-2010, 08:09 PM
  3. Handbrake preset question
    By Jake872 in forum iPad General Discussions
    Last Post: 09-20-2010, 04:17 PM
  4. MKV to iPad with Handbrake?
    Last Post: 09-14-2010, 07:52 PM
  5. iPad Converter - Handbrake
    By faisj in forum iPad General Discussions
    Last Post: 05-28-2010, 09:18 AM
best handbrake settings for ipad
best handbrake settings for ipad 2
handbrake ipad 2
handbrake ipad 2 download
handbrake ipad 2 settings
handbrake ipad settings
