Last longer now that I had my iPad 2 almost two months. I still have 4.3 iOS on it and somehow the battery drainage stopped happening. Anyone having the same experience?
This is a discussion on Battery starting to... within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Last longer now that I had my iPad 2 almost two months. I still have 4.3 iOS on it and somehow the battery drainage stopped ...
iPad 2 32gb Black ATT 3G
Have you started charging the ipad with a 10W wall charger? I noticed mine last considerably longer compared to when I'm charging it using a usb cable connected to a pc/laptop.
iPad 2(4.3.2) 32GB WIFI White
Yes, big difference when charging via USB. I put in on charge overnight and in the morning was only 41% charged. Much better when charging with AC.
Sent from my iPad 2 using iPF
iPad 2 3G 64Gb
The iPad only charges at normal speed when it is connected to the wall charger it came with. The iPad charger supplies 10W(5V, 2A), where as the laptop USB slot only supply ~0.5A, so charging the iPad via laptop can be really slow.
iPod and iPhone charges are also slow in comparison.
This is a suggestion from Dontunderstandmyipad by the way!
from Somerset UK on my iPad using IPF app
IPad 3 32GB wifi, 2x iphone 4, iPhone 3GS 32GB , ipad 1 32GB ,2x iPod touch 2G, BT keyboard
All for One and One for All!!!
From Somerset UK
I updated my pc drivers with Asus AI charger, improves the USB output power, iPhone charges faster now as well. There also work on my Dell Precision and Toshiba Satellite.
iPad 2 64Gb Wifi & 3G
iPhone 3GS 16Gb
iPod Classic 6th Gen 80Gb
