iPad2 Wifi N speed 1/2 of what it should be?
This is a discussion on iPad2 Wifi N speed 1/2 of what it should be? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I've got BrightHouse Networks as my ISP. They sell 'Lightning', a 40Mbps service, which I use. 4 computers and the iPad are on the home ...
Results 1 to 10 of 17
    54650
    May 2011
    Clermont, FL.
    15
    4 computers and the iPad are on the home network. 3 are hard wired. Using Bright House Networks Bandwidth Speed Test I test all 4 computers. All are showing over 38Mbps down and over 4.8Mbps up. Even the wireless connected computer, which is N and connects at 270Mbps is showing the same speeds. I tried the above site on the iPad but it is Flash based so I can't run it on the iPad. However I did get some speed test apps from the app store. The BEST speed I ever get is around 20Mbps down with 2Mbps up. Many times more around 10 to 12Mbps down with less than 1Mbps up. However, those are taken a good distance from the router.
    I don't own the router, BrightHouse does and they manage it. They will reset any parameters I change it seems other than 'normal' ones I can set.
    I've got the following Wireless settings in the Router (which I can change). See attached screen capture.
    I've seen some internet posts that suggest the problems lie in the above settings. I've moved the bandwidth to the 20Mhz band, the sideband to lower, and the control channels have been tried on a few different ones. I know the 5.0GHZ shouldn't work. Still, even with those changes, the speed readings do not change much is any.
    From what I can see, the iPad2 is running at 1/2 speed of the others on the network? Even when placed right next to the router?
    WPA-PSK is the security that is running? AES is the encryption. WPA-PSK2 is available to be used as well (not sure why it isn't on?).
    And idea or suggestions?
    Irv S.
    Attached Thumbnails Attached Thumbnails iPad2 Wifi N speed 1/2 of what it should be?-capture.jpg
    iPad Guru
    30446
    11 times
    3,197
    The iPad doesn't have a true .11n antenna, as a result, the highest speed you will ever get in real life is around 20 Mb/s. Essentially the .11n is only slightly faster than the .11g network. The highest theoretical throughput of the iPad's antenna is 65Mb/s, even when it is on a .11n wifi network, which can support 300Mb/s.
    The reason being that the way the wifi antenna was built, it doesn't support the features which make .11n faster than the the .11g wifi.
    Anyway, if you want to know the exact reason and a bit more, on why the iPad is not a true .11n compatible wifi device:
    http://www.sniffwifi.com/2010/04/app...y-another.html
    54650
    May 2011
    Clermont, FL.
    15
    OK, thanks...
    I read the article but to me it seems a 65Mbps would be the max. one could get, no?
    Is there anyway to tell how your connection is, I mean the Mbps speed of the connection?
    Irv S.
    iPad Addict
    37720
    6 times
    Colonial Heights,Va
    1,395
    Have you recently updated your firmware on the Ipad? If so try delete your network on the Ipad and put it back in. I've read where sometimes after an update the wifi is sluggish until that is done.
    There is an app called Speed Test. Its free
    Support Our Troops!!
    This post was Tapatalk approved. Sent from my Inc
    54650
    May 2011
    Clermont, FL.
    15
    OK, just did that, re-connected and had to give the p/w...
    I did update the OS a week ago but the problem has been from day one.
    I used SpeedTest X for the iPad, about 8 feet from the router, 11Mbps down, 3.4Mbps up.
    There is another that is for the iPhone, Speedtest which uses SPEEDTEST.NET. It shows 21.58Mbps down and 4.18Mbps up (max. I can get it 5.0Mbps up from the service).
    Irv S.
    7489
    126 times
    Jun 2010
    Sacramento, California
    14,962
    Quote Originally Posted by Mountainbikermark View Post
    I think this happened to me. And you told me about Speed Test ~ which I forgot to get!
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
    iPad Guru
    30446
    11 times
    3,197
    Quote Originally Posted by IrvSp
    Irv S.
    That sounds about right. 22Mb/s is the max mine ever got with speediest.net and that was using a fiber-optics inet connection.
    The wifi protocol is fairly inefficient, so you will rarely ever reach a throughput of 50% of the theoretical throughput. So your iPad is performing normal, it's just the design of the wifi antenna which prevents faster transfer speed.
    iPad Addict
    37720
    6 times
    Colonial Heights,Va
    1,395
    Sweet Poison ,It was probably Tim that wrote about the wifi sluggishness. He was the first I saw post it down and saw many others quote it though Tim stated he got it somewhere else.
    Speed test was one of the first apps I installed on my iPad to compare between my desktop, Inc and iPad. They all are about the same speed but I've got dsl so nothing is going to be maxing any numbers in my house.
    Speaking of that is there a way to FORCE the iPad to use "G"? Since the iPad is having compatibility issues with some "N" routers and they are backward compatible I'd like to set mine to G and see if the problem of the disconnects at various times on various networks is solved.
    Support Our Troops!
    235690
    Aug 2012
    Vic
    5
    Quote Originally Posted by DontUnderstandMyIpad View Post
    I have a 100Mbs Internet connection on shaw cable..you know that old copper wire. And a linksys e4200 router and on 2 and 5 ghz the iPad only gets 39mbs max.. My laptop get 90-110 Mbs on wifi and my pc gets 120 hard wired..
    Why does the iPad3 with that retina display have such a ****y network adapter.....
    215170
    9 times
    Jun 2012
    Cape Town
    389
    I've clocked 120mb on a D-Link N router on my iPad 3
  1. iPad WiFi to Router Speed?
    By jdag in forum iPad OS
    Last Post: 04-16-2011, 05:37 PM
  2. iPad2 WIFI - is it on? is it off?
    By nicolek in forum iPad Help
    Last Post: 04-02-2011, 04:50 PM
  3. Replies: 1
    Last Post: 03-11-2011, 02:05 AM
  4. Beware of the FCC WiFi speed test app
    By Billee in forum iPad General Discussions
    Last Post: 09-16-2010, 06:27 PM
  5. Wifi vs 3G wifi speed/reception
    By CPMS in forum iPad General Discussions
    Last Post: 05-03-2010, 10:25 AM
how to speed up ipad 2 wifi
how to speed up wifi on ipad 2
ipad 2 wifi performance
ipad 2 wifi speed test
ipad 2 wireless n
ipad 2 wireless speed
ipad check wifi g compatibility
ipad wifi speed
ipad wireless speed
maximum ipad wifi speed
what is the max wifi data rate for ipad 3
