ipad 2 will not connect to wifi
This is a discussion on ipad 2 will not connect to wifi within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I am at my second home and my new ipad 2 will not connect to wifi - previous ipad connected no problems - have changed ...
Results 1 to 10 of 17
    22513
    Nov 2010
    16
    I am at my second home and my new ipad 2 will not connect to wifi - previous ipad connected no problems - have changed nothing on settings etc. if finds the network no problem and the first day it was connecting and then dropping the connection within 30 second. now i just get the unable to join this network message any thoughts why the ipad 2 woud be having this issue while the ipad one never did
    37823
    479 times
    Cranbrook, Kent, UK
    15,265
    Quote Originally Posted by gcclubs
    I would reboot your router and your iPad. It's been known to work and better to start with the simpler things now.....may also be worth going into settings and forgetting your router from the wifi section at the same time.
    116 times
    15,249
    Quote Originally Posted by gcclubs View Post
    One of our moderators suggested this might help...
    "This has resolved many issues and worth a try.
    __________________
    Cheers
    Col
    col.bris, Brisbane Australia
    Forum Rules. Please Read.
    If there's still a problem, please get back to us and we'll try to suggest some other solutions
    22513
    Nov 2010
    16
    tried the suggested
    approaches and now I am getting a pop up box on ipad saying enter the password for my network but I don't have one set up - never had this message before and so the password I have to unlock the ipad doesn't work so I have no idea what to do now
    116 times
    15,249
    OK - this may sound a silly question, so please don't be offended but other Members have found this - are there any other WiFi networks in the vicinity? The iPad WiFi antenna is quite sensitive and we've had reports of Members' iPads trying to connect to a neighbour's WiFi network. You should be able to see the SSID of the network in the 'Settings' app on the iPad, which will enable you to confirm that it's your network that it's trying to connect to.
    iPF Expert
    33508
    108 times
    Feb 2011
    Somerset-UK
    7,875
    My iPad regularly tries going onto my BT Fon network which can be irritating but It is usually when I've gone out and then log in that this happens
    IPad 3 32GB wifi, 2x iphone 4, iPhone 3GS 32GB , ipad 1 32GB ,2x iPod touch 2G, BT keyboard
    All for One and One for All!!!
    From Somerset UK
    22513
    Nov 2010
    16
    Its my network as I see the name and my laptop is connecting to the wireless just fine. Now this moring it is back to just saying cannot join and has stopped asking for a password.
    any other suggestions as I have tested the wifi and its download and upload speeds are good and network magic makes it clear everything it okay. Its the Ipad 2 that is the issue
    iPF Expert
    33508
    108 times
    Feb 2011
    Somerset-UK
    7,875
    I'd take it back for a check up if I were you. If you have indeed tried all avenues, maybe it is your iPad.
    From Somerset UK
    22513
    Nov 2010
    16
    Return Ipad
    Quote Originally Posted by Hayles66 View Post
    I will do that but I am in the US and live in Canada. Ipad connects to to or three different networks at home no problems what so ever so I am pretty sure its not the ipad itself but maybe some settings or something. I guess I will know when I go to the airport tomorrow and see if it connects there.
    iPF Expert
    33508
    108 times
    Feb 2011
    Somerset-UK
    7,875
    Good luck and let us know how it goes, I'm sure one of us will be able to help you.
    From Somerset UK
  1. iPad 64GB WiFi problems (cannot connect)
    By BikerThomas in forum iPad Help
    Last Post: 12-27-2011, 03:53 AM
  2. Ipad 2 won't connect wifi after activate the 3G
    By caparuni in forum iPad Help
    Last Post: 06-13-2011, 01:16 AM
  3. ipad won't connect to home wifi now
    By yorky48 in forum iPad Help
    Last Post: 04-11-2011, 09:13 AM
  4. Ipad's unable to connect to 128 bit WEP wifi networks
    By mhalstern in forum iPad General Discussions
    Last Post: 01-11-2011, 01:15 AM
  5. How do you connect Wifi speakers to ipad
    By macfoot in forum iPad Help
    Last Post: 12-23-2010, 11:10 AM
ipad 2 does not connect to wifi
ipad 2 not connecting to wifi
ipad 2 wont connect to wifi
ipad not connecting to wifi
ipad will not connect to wifi
ipad will not connect to wifi after resetting
ipad2 will not connect to wifi
my ipad is not connecting to wifi
why does ipad say unable to join network
why does my ipad 2 not connect to the wifi
why does my ipad say unable to join network
