ipad 2 will not connect to wifi
This is a discussion on ipad 2 will not connect to wifi within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Does the router have DHCP enabled, meaning it distributes IP addresses automatically to any device connecting to the network? If you have never setup an ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    iPad Guru
    30446
    11 times
    3,197
    Does the router have DHCP enabled, meaning it distributes IP addresses automatically to any device connecting to the network? If you have never setup an IP address for your iPad 1, or laptop, it is safe to assume that it is enabled.
    Secondly, is there any chance that the router has a MAC filter enabled? It is essentially a whitelist allowing only devices with registered MAC addresses to connect.
  3. #12
    22513
    Nov 2010
    16
    Solved
    Quote Originally Posted by DontUnderstandMyIpad View Post
    I used network magic to rename router after resetting router and for whatever reason that did the trick and now iPad accesses perfectly. Thx for the suggestions
  4. #13
    iPF Expert
    33508
    108 times
    Feb 2011
    Somerset-UK
    7,872
    Yay! I was hoping something would work eventually.
    IPad 3 32GB wifi, 2x iphone 4, iPhone 3GS 32GB , ipad 1 32GB ,2x iPod touch 2G, BT keyboard
    All for One and One for All!!!
    From Somerset UK
  5. #14
    iPad Guru
    30446
    11 times
    3,197
    Quote Originally Posted by gcclubs
    That is an interesting approach. Cisco is definitely the correct company to buy such a network repair program from.
  6. #15
    203782
    May 2012
    Rockton, IL
    Resetting Network Settings
    Thanks Colonel,
    Resetting the network setting did the trick and I did not have to power the device off and back on for this to work.
    Cheers
    Paul
    One of our moderators suggested this might help...
    "This has resolved many issues and worth a try.
    __________________
    Cheers
    Col
    col.bris, Brisbane Australia
    Forum Rules. Please Read.
    If there's still a problem, please get back to us and we'll try to suggest some other solutions
  7. #16
    271429
    Jan 2013
    United States
    Thank you very much
    this worked perfectly for me
    __________________
    Cheers
    Col
  8. #17
    185635
    Apr 2012
    16
    I've been also told that to get consistent wifi on your ipad especially if you upgraded to IOS 6 and get intermittent wifi cutting off for a few minutes is to upgrade your firmware on your wireless router if your router does not have the current firmware in place and also clear the cache on all your browsers including safari.
    Sent from my iPad 2 using iPF
  1. iPad 64GB WiFi problems (cannot connect)
    By BikerThomas in forum iPad Help
    Last Post: 12-27-2011, 03:53 AM
  2. Ipad 2 won't connect wifi after activate the 3G
    By caparuni in forum iPad Help
    Last Post: 06-13-2011, 01:16 AM
  3. ipad won't connect to home wifi now
    By yorky48 in forum iPad Help
    Last Post: 04-11-2011, 09:13 AM
  4. Ipad's unable to connect to 128 bit WEP wifi networks
    By mhalstern in forum iPad General Discussions
    Last Post: 01-11-2011, 01:15 AM
  5. How do you connect Wifi speakers to ipad
    By macfoot in forum iPad Help
    Last Post: 12-23-2010, 11:10 AM
ipad 2 does not connect to wifi
ipad 2 not connecting to wifi
ipad 2 wifi not connecting
ipad 2 wont connect to wifi
ipad not connecting to wifi
ipad will not connect to wifi
ipad will not connect to wifi after resetting
ipad2 will not connect to wifi
my ipad will not connect to my wifi
why does ipad say unable to join network
why does my ipad say unable to join network
