how can i best ensure that the crack will not get bigger? i am not sure that cracks is included in the warranty but right now my primary concern is to make sure that the crack does not get bigger... any suggestions? please help.. thanks....
This is a discussion on help!!! my ipad2 glass case has a crack... within the iPad 2 Forum forums, part of the Apple iPad Discussions category; how can i best ensure that the crack will not get bigger? i am not sure that cracks is included in the warranty but right ...
Several members have reported that Apple take a very lenient view of screen cracks and will usually replace the iPad free-of-charge. It can't help to see if your local Apple Store will do this.
Yes, definitely talk to your local Apple Store first, if they don't replace it, you might want to consider the use of a screen protector.
i am in the philippines and the local apple store does not yet support ipad2 when i called them... they still do not have any instructions on the repairs and they informed me that it will be released in a week and i should call their engineering department to check when it is officially launched... right now,i guess, my best bet is to buy a screen protector, until i can talk to a representative...
