Results 1 to 9 of 9
    44436
    5 times
    Chicago
    338
    A Battery Question
    I'm getting my iPad 2 in roughly 90 minutes after waiting for 3 1/2
    weeks.
    My question is about the battery. It use to be that you had to charge up the battery of whatever tech that you were using for a full 18 to 24 hours before you used the tech in question. This was required for the battery to hold a full charge. I am, of course talking about the old nickle cadmium batteries. Is it neccesarry to fully charge the iPad like that before I use it or (once I sync it) can I use the machine right out of the box? Thanks.
    7489
    126 times
    Jun 2010
    Sacramento, California
    14,962
    Yay!
    You can use it right out of the box, I think I did. But I can't remember how much charge it came with ~
    But why not just charge it?
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
    116 times
    15,249
    Quote Originally Posted by Appsempire View Post
    weeks.
    An iPad battery comes, more-or-less, fully charged. There's no need for any special precautions. Charge as often - or as infrequently - as you like. The iPad is 21st century, so none of those old precautions apply. Apple want you to be happy so they used some ultra-sophisticated battery charging electronics in the iPad. Leave it on charge all day - no problem. Let the battery go completely flat - no problem (though you'll need to charge it before you use it then, even Apple can't control the Laws of Physics - yet!).
    But, don't believe me, read the official line...
    Apple - Batteries - iPad
    37823
    538 times
    Cranbrook, Kent, UK
    15,671
    Quote Originally Posted by SweetPoison
    Yay!
    Like Mrs P says, use it right out of the box, once it's synced stick it on charge while you play with it......don't forget it has to be plugged into the mains to charge, it won't charge through the USB but it will hold it's charge b
    44436
    5 times
    Chicago
    338
    Thank to all of you for your help. This is the first Apple product I've ever bought so I got a lot to learn.
    37956
    UK
    74
    Quote Originally Posted by Gabriel1
    It will charge from a USB port on a computer but at a slower rate, it says its not charging but it is, it just takes longer, I've read however that if using it while plugged into the USB, depending on what you're running at the time, it may not charge. Apple also recommend running the battery out, and a full recharge once a month to keep the battery meter calibrated. Mine also came fully charged out of the box.
    A direct quote from Apples battery page.
    Use Your iPad Regularly
    For proper reporting of the battery’s state of charge, be sure to go through at least one charge cycle per month (charging the battery to 100% and then completely running it down).
    iPad Addict
    15631
    2 times
    Sep 2010
    Sydney
    1,078
    Quote Originally Posted by Gazzaho
    A friend had a problem with the device's battery meter: no matter how much he charged it, it always showed 2% (obviously not the case). A reset fixed the problem.
    32GB WiFi
    37972
    138
    It's a lithium ion battery; that full charge rule applies to older nickel based batteries.
    Nickel based batteries needed this because nickel is a "memory" metal that needed full charge and discharge cycles for it to remember it's capacity.
    Lithium based batteries are "smart". They have electronics in them to tell when it's full or discharged. Lithium batteries need to be discharged and charged fully every so often so that the smart circuitry can re calibrate (it will account for any battery degradation, which will happen).
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,284
    I ran an iPad1 for last year without a full discharge and no obvious bad effects.
    Battery life appears as good as it was when bought.
  1. battery question
    By sjleworthy in forum iPad 2 Forum
    Last Post: 04-10-2011, 06:28 PM
  2. Battery Question
    By Gant22 in forum iPad General Discussions
    Last Post: 01-17-2011, 07:25 PM
  3. iPad battery question when charging
    By J.D in forum iPad Help
    Last Post: 01-14-2011, 01:58 AM
  4. Battery question
    By DashSatan in forum iPad General Discussions
    Last Post: 12-26-2010, 01:57 PM
battery
can you use ipad 2 right out of the box?
can you use the ipad 2 right out of the box
charging ipad out of box
charging the battery on a new ipad
do i need to charge my ipad out of the box
ipad battery completely flat
ipad completely flat
out of the box ipad 2 battery
should u charge an ipad for 24 hours out of the box
should you charge ipad 2 out box
what to do on the out of the box ipad 2 battery
Tags for this Thread
