iPad locked up
This is a discussion on iPad locked up within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I saw that there is an update for the Ipad operating system, so I clicked update and for the past four hours my PC screen ...
Results 1 to 5 of 5
Thread: iPad locked up
    3606
    May 2010
    melbourne fl
    8
    iPad locked up
    I saw that there is an update for the Ipad operating system, so I clicked update and for the past four hours my PC screen shows "waiting for Ipad" and my Ipad shows a white USB cable pointing up to an Itunes symbol.
    I have 4.3.1 currently.
    When I try to shut off the PC, it says I will have to force the shut down since Itunes is running.
    Any Ideas how long this should take or what I might try?
    Banned
    48444
    Wales
    667
    Try closing iTunes first. If the graphic on your iPad disappears, then unplug the device from the USB port, reboot your PC start iTunes and try again. There is a big update to iTunes and safari today, so make sure you have that installed before updating your iPad!
    Hope this helps
    Jeff
    Banned
    48444
    Wales
    667
    Force the shut down. Disconnect the ipad. Re-boot PC and open Itunes. Check that the new updates have been installed (released yesterday.
    Try the ipad again. If this still fails you may be looking at a clean start of the ipad. Before even considering this use Itunes to make a media (DVD) backup of all your apps and music. Then if needed, Itunes can be uninstalled, then reinstalled and your apps and info will be automatically restored....Just insert the media in your DVD drive.
    Hope this works.
    Jeff
    3606
    May 2010
    melbourne fl
    8
    Thank you. I did what you suggested and Have everything back in order. Appreciate the help.
    Banned
    48444
    Wales
    667
    Glad it's all working now!
    Jeff
  1. Locked-up IPAD
    By hunch110 in forum iPad Help
    Last Post: 01-22-2011, 06:07 PM
  2. ipad locked up in ibooks app
    By jankitt in forum iPad FAQ
    Last Post: 01-20-2011, 10:03 PM
  3. Locked ipad
    By Rokr in forum iPad Help
    Last Post: 12-15-2010, 10:51 AM
  4. HELP! Locked out of my iPad
    By clangdon89 in forum iPad Help
    Last Post: 11-11-2010, 02:15 PM
  5. iPad locked up (?) during OS update
    By steven.lamb in forum iPad Help
    Last Post: 10-25-2010, 06:38 PM
apple ipad locked up
browse locked ipad from pc
ipad 2 locked up during update
ipad app locked up
ipad game locked up
ipad has locked up
ipad locked up
ipad locked up doing update, itunes with usb cable
ipad locked up during update
ipad locking up when updating app
ipad2 lock up after update
my game is locked up on my ipad
