On the iPad go into:
Settings
General
Reset
Try "reset settings"
If that don't work try "erase all content and settings" which will set back to factory default. Camera app should work then.
You should be able to sync your apps/music back thru iTunes as normal.
LinkBack URL
About LinkBacks
