Will an iPad2 recognize and import video from a Flip Camera?
This is a discussion on Will an iPad2 recognize and import video from a Flip Camera? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Will an iPad2 recognize and import video directly from a Flip video camera? If so, which models? What app will do the import? iMovie? If ...
Results 1 to 10 of 10
    46815
    Virginia
    9
    If not, what other video cameras will iPad2 recognize and import video from?
    Thanks,
    Hal
    41494
    13
    I haven't tried it yet, need to get Flip from my son tonight, but Check This Out...
    55125
    May 2011
    Meaford, On
    Flip tech support say no...
    But
    Yes. The trick is to use a powered USB hub between the pad usb camera connector and the flip.
    Connect them up, go to Photos and your flip contents should appear. Works for me.
    25454
    Dec 2010
    Kansas
    19
    All you have to do is power on the flip before plugging it into the iPad USB port. I shot video of my nephews wedding with my flip and had it on my iPad before the reception started.
    25454
    Dec 2010
    Kansas
    19
    Quote Originally Posted by tecwritr
    You do not need a powered USB port.
    55125
    May 2011
    Meaford, On
    May work on a Flip Mino without a powered USB hub but not on the UltraHD which tries to draw power from the USB, without the Powered USB you will get an error message on the iPad.
    25454
    Dec 2010
    Kansas
    19
    I am using a Flip Ultra HD. I do not need a powered USB to download to my iPad 2.
    25454
    Dec 2010
    Kansas
    19
    You have to have the Flip turned on before you connect it.
    11919
    9 times
    Aug 2010
    Virginia, USA
    718
    Page 69 of your operating manual
    tells you what formats work for you.
    "iPad supports H.264 and MPEG-4 video formats, with AAC audio. You use iTunes to sync videos taken with a digital camera, iPhone, or iPod touch (4th generation) to iPad."
    If my Irish Wolfhound doesn't like you neither will I.
    2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
    iPad Enthusiast!
    22751
    Nov 2010
    Arizona
    90
    Need to convert the codex
    I use the comparable cam by Panasonic. The output should be the same (mpeg4). You will need to convert the file to one that will load on your iPad. Go to iPadinTouch - iPad Converter Reviews, iPad News Tips, Games and Apps. and at the top, click on "Best DVD to iPad". There are a few you can download a free trial version. With the software, make sure you select the appropriate device you wish to use the video on, and select the best quality output. You will notice a selection for the iPad 720P. It works great. I can even convert all my AVCHD videos as well. Once you have finished the conversion, simply place the file in your iTunes library and your good to go. Keep in mind that the trial version will only produce a maximum video length of 5 minutes, so you will need to purchase the software to take full advantage. Good luck.
    You can use iTunes to do the conversion, but because mpeg files are quite large, it takes forever. The software I mentioned is much faster, and you have better control of the final product.
  1. Replies: 2
    Last Post: 04-13-2011, 07:43 AM
  2. Camera Connector Kit only 1-way import from SD card?
    By PrimoOptimoso in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-28-2010, 05:22 PM
  3. Problem with Flip HD and camera connection
    By Mikeb41g in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-18-2010, 10:42 PM
  4. Cisco suggests WiFi Flip Video camera by Christmas
    By iPadPil in forum iPad General Discussions
    Last Post: 07-01-2010, 09:57 AM
can you download software for the flip video on an ipad
connecting flipvideo ultra to ipad
download videos to ipad from camera
downloading flip ultrahd video to my ipad 3
flip video for ipad 2
how to download flip video to ipad 2
how to download video from camera to ipad 2
how to download videos from flip camera to ipad
how to import video to ipad 2
howdownload video from camera to ipad2
importing camera videos to ipad2
ipad will not recognize ultra hd flip camera
Tags for this Thread
