Gps?
This is a discussion on Gps? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I am pretty much sure you have post this somewhere and I am sorry if I double this. 32GB 3G ATT gps turn by turn ...
Results 1 to 4 of 4
Thread: Gps?
    iPad Enthusiast!
    46102
    Chicago
    30
    Gps?
    32GB 3G ATT gps turn by turn navigation can work without data plan?
    Am I right or not and how accurate this will work without data in case I travel in US?
    Thank you.....!
    Sent from my android galaxy s phone using iPad Forums
    40617
    2 times
    Homeless
    198
    No data plan required for the GPS receiver to work.
    Depending which GPS app you are using you may need to be connect WiFi for it to download the map. In other words you would have a nice blue dot in the middle of a blank screen.
    However there are several GPS app's that download the maps so you do not have to be connected to anything to use them.
    I use Nav Free USA which is free.
    Rudy Ackerman
    Currently on the road and homeless
    The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
    iPad Guru
    30446
    11 times
    3,197
    GPS doesn't use 3G for location finding, so it will be as accurate as any GPS device without external antenna.
    iPad Enthusiast!
    46102
    Chicago
    30
    Thank you so much guys!
gps
gps for ipad, no network needed
how does navfree work
how much data needed for gps
how to use gps on ipad 2
how to use navfree on ipad
instructions using navfree app
ipad gps app no data
navfree ipad no data
navfree no data
navfree not working
navfree not working ipad
