I fell asleep waiting for it to fully charge only to wake up 6 hours later. Will this hurt my Ipad or its battery?
Doubt it.
Left my iPad1 charging overnight loads of times without any problem.
As long as it works, you're good to go![]()
The charging stops, once it reaches 100%. So it doesn't matter, if you leave it plugged in.
The iPad can be left permanently connected to the charger, if you wish (I do). It has a highly 'intelligent' charging controller that automatically controls the precise charging current. There is no chance of the iPad being 'overcharged', as might have been the case with similar devices many years ago.
I panic and thought the battery was going to decreased its prefomance but is good to know it doesn't hurt at all.
Thanks to all of you for your reponses.
When I connected my new IPad 2 to my PC using the USB port I got a little message saying " not charging". Well I left it hooked up anyway, ( this is how I ALWAYS charge my IPOD TOUCH) and in about 3 hours it was back to 100 per cent. So you can recharge your IPad from your pc. When I travel I have to make sure to have all the charging tools along. One for the phone, one for the laptop, one for the camera. My IPad 2's battery is quite incredible as to long lasting ability compared to my laptop ( which I havent used since I got the new IPad 2) cheers.
The supplied iPad charger is a 10W device that can charge at about 2A. A regular USB port on a computer is limited to about 500 mA - or about a quarter of the iPad charger's output. So, yes, you can (slowly) charge the iPad from a USB port - but it will take significantly longer to charge.
I leave mine on power over night it is fine no problems
Cheers Colin,
Brisbane Australia
_____________________________
iPad User Guide
Forum Rules. Please Read.
Hacking Section Rules
What about that ASUS utility that allows standard USB ports to charge the iPad? Does anyone know if that really causes the USB port to supply more power or is it just somehow "fooling" the iPad to think it's providing more power than it really is? I just don't understand how a simple app can increase the amount of power that the USB port can output, especially since it seems to work with all motherboards (all I've tried anyway)!Originally Posted by Tim SPRACKLEN
Anyone really know if it charges any faster (or at all) when using the ASUS utility?
Thanks!
A little off topic but interesting. I'm not sure 500mA limit is due to the USB or just being limited by the PC to protect devices attached to USB.
For orignal topic, most electronics since early 90's know to stop charging as soon as battery hits 100%. Recently, most electronics will begin trickle charging around 95% to ensure battery longivity. Even if the device says 100% charged it can be hanging around in actuality between 95-100%.
