first ipad
This is a discussion on first ipad within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I am new to the world of iPad (as far as physically having one). I have no issues with my device, no bleeding, crashing, no ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: first ipad
    iPad Addict
    39793
    7 times
    Oxford, MS
    1,044
    first ipad
    I am new to the world of iPad (as far as physically having one). I have no issues with my device, no bleeding, crashing, no faulty wifi or FaceTime. I haven't upgraded to 4.3.2, but all is well. I just have one small incy wincy issue. That is: what is the average time it takes to get to full charge. I am pulling an all-nighter for a paper. I am just taking my time and working slowly over my tracks. When I opened my package, the iPad was at about 87%, which was good. I didn't charge it. I just synced it and went from there. I was working ON THE IPAD, but I have switched to a desktop. I am just using the iPad to stay awake, watching NETFLIX (flawless playback by the way). When I started charging 5 hours ago, it was on 45%, now its on 70%. Is this because I am actively using the iPad while charging or because it just charges slowly? I am using the OEM sync cable and all is well. Should I turn it off while I finish my life. What are your thoughts. I'm open for suggestions...
    BTW I LOVE MY IPAD!
    Sent from my iPad 2 using iPF
    [COLOR="] If you don't know me by now, I will never ever ever leave Apple. [/COLOR]
    iPad Guru
    30446
    11 times
    3,197
    Quote Originally Posted by HKWrite12
    This was too funny. I had no idea you already reached that part of your life.
    Anyhow, using the iPad does use up the battery, so it is to be expected that charging takes longer. When mine charges from 0%, it can take up to 12h to reach a full charge, depending on the usage. It is much faster when the iPad is asleep.
    116 times
    15,249
    I'm assuming you're using the supplied iPad charger. Yes - when you're using the iPad and charging at the same time it most certainly takes longer than if you're charging an iPad that's switched off completely or in Sleep mode. Your times seem about right to me. No need to worry, though. Enjoy watching Netflix...
    Glad you have no problems with your iPad....
    29345
    49 times
    Penarth, Wales, UK
    1,935
    i find my ipad charges normally (over a few hours) as expected when plugged into the mains, but when on my office desk all day it's plugged into the usb, which isn't strong enough to charge as you'd ideally like (it does charge but very very gradually), but at least this keeps the charge so to speak. plugging it into my use on my desk top pc keeps it at a good constant level when i then use it during the day.
    iPad Addict
    39793
    7 times
    Oxford, MS
    1,044
    Thanks guys. I don't know what word I was Tryna put when life came up. I turned it off and plugged it in the wall again. I need it to fill up. Were gonna have a long day tomorrow if I don't pass out.
    iPad Addict
    39793
    7 times
    Oxford, MS
    1,044
    My battery life is awesome, i have done everything from netflix to pandora to writing and playing puzzles. The battery is just slipping like one percent every 10 minutes.
    29345
    49 times
    Penarth, Wales, UK
    1,935
    Must admit I haven't tested my battery out yet.
    I charge it up to 100% for the start of each day, before I unplug it and stick it on my office desk for general office usage. By end of day it's probably down to maybe 30-40%. That's pretty amazing. My Touch runs out very fast unless it's on a constant charge.
    iPad Addict
    39793
    7 times
    Oxford, MS
    1,044
    Quote Originally Posted by sjleworthy
    What gen is touch.
    iPad Addict
    39793
    7 times
    Oxford, MS
    1,044
    Having another issue. I was seeing ppl mentioning wifi issues and now I'm in that same boat.
    I had these same problems with my phone at some point.
    I'm at a university and have to login to a server for wireless. This is usually a matter of clicking join and typing but sometimes it freezes the iOS product or won't pop up.
    I've been online all day and had just finished watchig a moving on airvideo. Brief break ad wifi times out. I've been trying for an hour to get a reconnect. No luck. What to do guys?
    45186
    Barry, Wales
    34
    You may need to update the OS as I heard that this might fix the problem. It's worth looking around to see if this does indeed help first before you jump in and update though I would say.
charge and use ipad2 at the same time
initial charging time for ipad
ipad 2 initial charging time
new ipad3 charge initial
