Quick question
This is a discussion on Quick question within the iPad 2 Forum forums, part of the Apple iPad Discussions category; My iPad 2 is waiting for me at home (spring break starts thursday) so obviously I don't have apps on it. Can I download apps ...
Results 1 to 7 of 7
Thread: Quick question
    iPad Enthusiast!
    37128
    56
    Lightbulb Quick question
    Can I download apps now from the app store and just synch them to my iPad thursday? or should I just wait until I get my iPad and just download directly from there?
    32gb black iPad 2
    29345
    49 times
    Penarth, Wales, UK
    1,934
    Either, makes no odds.
    20755
    7 times
    Nov 2010
    Michigan
    436
    Just make sure you're downloading iPad apps into iTunes, and not Mac apps onto your computer.
    40617
    2 times
    Homeless
    198
    depending on the app and your internet connection it may take a while to download some of them. It wont hurt anything to start down loading some now.
    Make sure you have the latest ver of Itunes other wise it may not even see your ipad2.
    Rudy Ackerman
    Currently on the road and homeless
    The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
    iPad Master!
    545
    Feb 2010
    340
    I pre-baught several Apps, the iWork stuff, GarageBand, GoodReader for iPad, and a few others that I had already noted as being useful to me. Some of it I just brought over from my iPod.
    I assume you don't have an iOS device yet? You can use iTunes to shop around for Apps. In many ways its actually easier to find stuff through iTunes then through the App Store on the iPad. Also you can get supplemental reviews of Apps before you buy. The screen shots are far to limited to fully research how an App functions.
    Add 202 to my user number and call me an Airplane.
    --iPad 2 64 GB Black WiFi "Dynabook 2011. With know-how and integrity"
    iPad Enthusiast!
    37128
    56
    Cool, thanks for all the replies, you've all been helpful. And yes, this is my first IOS device and I cannot wait to get my hands on it.
    I guess I just wasn't sure if the iPad is "based" in iTunes. Apple probably didn't anticipate that it would ever support a device like the iPad.
    So when I synch the iPad it will be almost like updating the library on my iPod? (Relatively fast)
    In any case, i'm off to download some apps
    32gb black iPad 2
    iPad Master!
    545
    Feb 2010
    340
    Keep in mind you are syncing over a USB2 cable, so data transfer will about as fast as any kind of transfer to USB flash or external hard drive. The first time you load content will take a while, especially if you are like me and dump 32 or so gigs worth of video into the thing.
    Unlike your standard iPod (not the Touch as that is an iOS device), the iPad will have Tabs for Apps, Music, TV Shows, Movies, Books (audio and ebook), and Podcasts. From these tabs you can control what does and does not get synced to your iPad.
    Right now I actually only have it managing my Apps on my iPad 2. I've turned it on to Manually Manage for movies and audio (I have not put audio on... that's what my iPod Touch is for ).
    Also be aware that in the Apps tab, when you scroll down you will find all the Apps that have internal storage that is accessible by iTunes. This is handy for things like GoodReader or Pages so you can transfer document files to and from the iPad by USB through iTunes if need be.
    Another trick I've found in managing my iPod's music was to create a Smart Playlist that looks for the line "For iPod" in the comment section of music. I then sync just that smart playlist to get my master collection of music I want only one my iPod synced. If it comes down to it I may eventually do the same thing for my iPad, creating a new smart list looking for "For iPad" that way I can keep the two syncs distinct.
  1. Hello from Minnesota and a quick question.
    By MNBud in forum New Member Introductions - Site Assistance
    Last Post: 03-25-2011, 12:16 PM
  2. Hi and a Quick Question
    By greyysha in forum New Member Introductions - Site Assistance
    Last Post: 01-23-2011, 08:29 PM
  3. Quick question.
    By Dan-app in forum Off-Topic
    Last Post: 01-01-2011, 09:03 AM
  4. Quick Question
    By painbringer112 in forum iPad Hacking
    Last Post: 09-06-2010, 02:47 PM
  5. Quick Question.
    By DG~X in forum Off-Topic
    Last Post: 01-27-2010, 10:06 PM
