Battery tip
This is a discussion on Battery tip within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Probably lots of you know this but I didn't. I was getting lackluster to bad battery life on my iPad 2 until an Apple store ...
Results 1 to 10 of 15
Like Tree1Likes
Thread: Battery tip
    40555
    Fort Lauderdale
    Battery tip
    Probably lots of you know this but I didn't. I was getting lackluster to bad battery life on my iPad 2 until an Apple store employee noticed that virtually all of my apps were running in the background. Since shutting down any apps that I don't need to keep running in the background I'm getting the 10 hours battery that the iPad 2 is advertised to get.
    43611
    Bermuda
    14
    But can we tell what's actually running and using battery power?
    I'm assuming that you check to see what's running by double clicking the centre button. I thought that this was just to show the history of usage but does it also mean that all of the aps shown are still running and using battery power? All of them?
    20755
    8 times
    Nov 2010
    Michigan
    436
    That's the multitasking bar, all those apps are "open", but generally in a "hold" mode. It makes jumping from one to the other faster than actually closing and reopening them. Not all "open" apps use power, but some can. To close them completely, double click the home button, then press and hold an app until they wiggle. Press the "minus" symbol in the upper left of each app you want to close. Hit the home button once to stop the "wiggling".
    29345
    55 times
    Penarth, Wales, UK
    1,996
    Quote Originally Posted by Jeeper View Post
    Yeah.
    I've usually only my most used apps always open in the background. Only 3 or 4. The less open the better the battery performance and general speed.
    44755
    4 times
    Central Pa.
    67
    Thanks. I missed that. I had waayyy too many apps open.
    iPad Junkie!
    46597
    Canada
    166
    According to Steve jobs, you aren't supposed to worry about what's running in the multitasking bar. The os is supposed to handle it. If it actually does hurt battery life, it's going to be pain for me to remove all those apps.
    1596
    334 times
    Mar 2010
    5,307
    I suspect one of your apps is the problem which is causing the battery to drain. I havnt removed my apps for days and have no issues with battery life
    Cheers Colin,
    Brisbane Australia
    _____________________________
    iPad User Guide
    Forum Rules. Please Read.
    Hacking Section Rules
    44227
    3 times
    355
    Quote Originally Posted by col.bris View Post
    Same here, I never close any apps manually & my battery life is right where it is supposed to be.
    ~John
    45656
    Sweden
    7
    Same for me too - I don't close any background apps manually, unless for some reason need to restart them, and I'm getting great battery life. It's now been on for nearly 16 hours with a LOT of active use (surfing, games, videos, photos and more) and it's on 7%. Overall I'm really impressed by the battery life on this thing!
    iPad Enthusiast!
    12114
    Aug 2010
    31
    If you push something that uses your connection or GPS to the background, it will continue to run the wireless/receiver and drain the battery faster. The rest are not as "thirsty."
  1. The battery!
    By normanj in forum iPad General Discussions
    Last Post: 03-07-2011, 09:40 AM
  2. Battery
    By Larrybe in forum iPad Help
    Last Post: 01-02-2011, 11:07 AM
  3. Battery?
    By HUNTER1 in forum iPad General Discussions
    Last Post: 11-30-2010, 09:31 AM
  4. how does the battery like this???
    By Spielor in forum iPad General Discussions
    Last Post: 10-29-2010, 12:52 AM
  5. I just got my 2nd battery
    By Sincere11105 in forum Off-Topic
    Last Post: 05-01-2010, 07:57 PM
bad ipad battery
can ipad 2 battery go bad
does ipad battery go bad
how can i tell if my ipad battery is bad
how do i know if ipad battery is bad
how to determine if bbattery is going bad on i pad
how to tell if ipad battery is bad
ipad bad battery
