Charging question
This is a discussion on Charging question within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi there, I bought my first iPad,the 16 gb 2nd gen, and I love it ( also have a 4th gen touch). I have read ...
Results 1 to 8 of 8
    45626
    Bc,canada
    Charging question
    Hi there, I bought my first iPad,the 16 gb 2nd gen, and I love it ( also have a 4th gen touch). I have read many, many threads and still have a couple questions... bought a smart cover,which I like, but also bought a leather case,which I feel offers more protection...i am getting differing opinions everywhere i read about whether it is safe to charge in the case? really interested in whether this is ok... If have also read a lot of different stuff on the best thing to keep your battery at its best, and it also confuses me! I know i should do a full charge/discharge every month, but should I run it low before i charge, or only partially down...I look forward to anything anyone can tell me, I truly appreciate it...I can't tell you how much I love my iPad,it is awesome!
    iPad Guru
    30446
    11 times
    3,197
    You can charge the iPad, while it is in the cover. The heat produced is not enough to cause any problems.
    Regarding preservation of the battery, use partial discharges, if possible, I.e. run it down to 50%, then charge again to 95%.
    However, what is not advisable is to run the battery down completely on a regular basis, though once a month is fine for keeping the battery indicator accurate.
    But imo, the iPad should be used, if the optimum charging goes against your usage, then just use the device, that is what it was bought for. Besides, the battery preservation will be minimal either way.
    40751
    sebek.pr@gmail.com
    14
    Quote Originally Posted by DontUnderstandMyIpad View Post
    Extremely useful info! Thanks!
    45626
    Bc,canada
    Thanks so much for the reply, i really appreciate it! and great info
    45322
    AZ
    338
    I charge mine every nite or when I'm not using it!
    iPad Enthusiast!
    47284
    40
    Just another related question: Should the iPad 2 initial charge be in any certain way? Should I charge it for maybe 10 hours the first charge or just until it shows that it's fully charged?
    iPad Guru
    30446
    11 times
    3,197
    Quote Originally Posted by Laban
    That is nothing to worry about. There is a reason, the iPad gets delivered charged.
    iPad Enthusiast!
    47284
    40
    Aha, alright! Cool. Thank you!
  1. Charging question?
    By iceman72 in forum iPad 2 Forum
    Last Post: 04-09-2011, 05:01 PM
  2. Replies: 7
  3. iPad battery question when charging
    By J.D in forum iPad Help
    Last Post: 01-14-2011, 01:58 AM
  4. Charging???
    By HarlyFan in forum iPad Help
    Last Post: 07-12-2010, 08:51 AM
  5. Question On Charging Ipad
    By Al Rogers in forum iPad Help
    Last Post: 05-26-2010, 01:48 PM
how many hours we have to charge the ipad for the first time before using
is it ok to part charge an ipad batery
is it ok to partially charge an ipad
is it ok to partially charge ipad
is it ok to use ipad 2 while charging
is it ok to use the ipad while it is charging
is it okay to partially charge ipad
is it okay to partially charge your ipad
is it okay to use ipad while charging battery?
is it safe to use ipad while charging
new iphone charging first time
