Why the 30 pin?
This is a discussion on Why the 30 pin? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Why does the iPad 2 use a 30 pin connector? The entire world is on mini USB or micro USB. Why does such a green ...
Results 1 to 7 of 7
Thread: Why the 30 pin?
    36299
    19 times
    500
    Why the 30 pin?
    Why does the iPad 2 use a 30 pin connector? The entire world is on mini USB or micro USB. Why does such a green company force their customers to buy and use a proprietary connector? They don't need 30 pin to sync a device. Has there ever been a need for the additional connections?
    iPad Master!
    545
    Feb 2010
    340
    Two reasons.
    1) Because Apple likes proprietary things don't ya know
    2) if you check the wiring the 30 pin port actually allows the iPad a greater range of output on one port. For example it can be a USB port or an HDMI port depending on the adaptor. A straight USB port could not do that, it doesn't have the throughput.
    Lastly any tech company who says they are green I'd lying to your face and they know it. There is no such thing as a green computer company. It's not just Apple who does it. For one they rarely factor in the disposal of old devises.
    Add 202 to my user number and call me an Airplane.
    --iPad 2 64 GB Black WiFi "Dynabook 2011. With know-how and integrity"
    36299
    19 times
    500
    I get it now. Thanks
    15889
    Sep 2010
    63
    just about every tablet is doing it now. the usb 2.0 specs only allow for 5v 1A for a total of 5watts. the newer tablets require more for charging at full speed 10watts for the ipad. i think the xoom is set for 18watts and charges in 3-4 hours (sorry i took my xoom back a week ago so memory's kinda foggy on that detail).
    the only recent tablet that charges via microusb (that i can think of) is the nook color, but it has a special cable to allow for full speed charging.
    37165
    Minnesota
    363
    Quote Originally Posted by zipur View Post
    "On you OP you asked why the 30 pin Connector." I get it now. Thanks
    As Dorje stated: " Because Apple likes proprietary things don't ya know"
    Now isn't it interesting how many look at proprietary as negative... when in actuality it is one of the fundamentals that enables Apple equipment and software work so well.
    But You ask why 30 pins ... and I say why not? By using that 30 pin port (that is common to all of Apple's mobile devices) Apple can address many more capabilities with an add-on adapter
    With Intel now bringing out all of the specifications for both USB 3.0 and Thunderbolt implementation it will be interesting to see how the high speed connections evolve.
    Also if you look at the fact that Macbook Pro already has Thunderbolt implemented, I suspect you will find that Apple will be using Thunderbolt as the interconnect between all of its hardware. Why bother with slow USB when High speed Thunderbolt is so much faster? I wouldn't be surprised if the A5 soc didn't have some unannounced goodies inside ... wait til iOS5 arrives.
    Check out John Gruber's first two topics on today's Daring Fireball
    Last edited by madhatter61; 04-15-2011 at 05:15 PM. Reason: had to simplify the post
    iPad Master!
    545
    Feb 2010
    340
    I'd like to believe that the IPad 2 30-pin was thunderbolt capable, but I highly doubt it. For the same reasons that the old FireWire to 30 cables don't really work anyone. Then again Apple could sneak in some kind of adapter.
    iPad Addict
    39793
    7 times
    Oxford, MS
    1,044
    Apple has two agendas:
    Make money.
    Make products that make money.
    Make Money.
    When you have ur own unique cable, you can't help but make money.
    Their second agenda is...
    I think you can fill in the blank.
    [COLOR="] If you don't know me by now, I will never ever ever leave Apple. [/COLOR]
apple 30 pin connector pinout
apple 30 pin usb cable color code diagram
doe ipad 4 have a 30 pin port
does the ipad 2 have a 30pin
how many pins does an ipad have?
how many pins does ipad 4 has
how many pins ipad 2
how many pins on an ipad
ipad 2 has how many pins
ipad 2 hdmi pinout
ipad 2 how many pins
why the new 30 pin adaptor does not work on my ipad 2?
