Results 1 to 10 of 14
Thread: iTunes Freezing
    39280
    Canada
    60
    iTunes Freezing
    iTunes is freezing-up about every 3rd or 4th time I connect my iPad2 to the PC. I have to close iTunes from Win 7 task manager (which shows it not responding) then manually restart iTunes where it connects to the iPad ok.
    Anyone else experiencing random freeze-ups?
    iPad-2 White WiFi 64GB
    iPod Touch 3G 32GB
    7800
    Jun 2010
    Oregon
    144
    I have had the same problem on occasion. Once I had to actually reboot my computer. Never did this with my first iPad.
    “It is a paradox that every dictator has climbed to power on the ladder of free speech. Immediately on attaining power each dictator has suppressed all free speech except his own.”
    iPad - 64G - WiFi - 3G
    iPad2 - 64G - WiFi - 3G
    39481
    4 times
    448
    It's not freezing it is just busy. Like every application when it says not responding you just need to be patient, it will continue.
    I have a lot of comics on my 64GB wi-fi 3G and when I connect to Itunes it takes a couple of minutes to read them all from the comiczeal app.
    If you don’t wait and shut it down with the task manager you could corrupt the data on your iPad and possible the itunes application itself.
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    I'm having the same problem with the iPhone, iPad 1, and iPod Touch. It's not busy doing anything as I have left it for several hours and it doesn't make any difference. Sometimes it will attach to the first device and sync OK, then when I plug in the next device, iTunes freezes. Stop it with Task Manager, unplug idevice, restart iTunes, plug idevice back in, good to go again. Sometimes just re-plugging in the idevice will un-freeze iTunes. I have re-installed iTunes. When I have some time, I will delete the devices drivers and re-install them, to see it that helps.
    Good Luck
    Pocobear
    39481
    4 times
    448
    Hours means frozen for sure. I have seen some apps take up to 10 minutes to catch up. But never hours.
    39481
    4 times
    448
    I have also never hooked up two or more devices at one time. I have many I just uses them at different times.
    iPad Enthusiast!
    39019
    Midwest
    66
    Quote Originally Posted by Tom P. View Post
    Same here. I restart the computer and all is fine. Never started happening until the past couple of months.
    36085
    13 times
    n/a
    481
    Try turning off Genius for the time being and then check your iTunes data for issues. I had an errant entry in my music that was making it freeze. I fixed it and haven't had an issue since. And yes, I have since turned Genius back on.
    39481
    4 times
    448
    I would turn off Ping also if you are not using it.
    39280
    Canada
    60
    Genius and Ping are both turned off. I have never used Genius (make my own playlists) and Ping was disabled as soon as I got the iPad. It is a randomly occurring problem with iTunes. When it works, my iPad connects to iTunes within a few seconds. It sync's much quicker than my iPod Touch even though I have a lot more loaded on the IPad.
    Sent from my iPod-2
    iPod Touch 3G 32GB
  1. BBC iPlayer freezing
    By vitesse67 in forum iPad Help
    Last Post: 07-19-2011, 05:15 PM
  2. Facetime freezing?
    By Mark4777 in forum iPad 2 Forum
    Last Post: 04-26-2011, 11:30 AM
  3. Freezing when loading
    By Howard kelly in forum iPad Help
    Last Post: 10-03-2010, 03:23 PM
  4. Freezing when connecting
    By Jayjayphoto in forum iPad Help
    Last Post: 06-11-2010, 10:39 PM
  5. Apps Tab On iTunes Freezing
    By AKNorth in forum iPad Help
    Last Post: 04-04-2010, 08:08 PM
ipad 2 freezing on itunes
ipad itunes freeze
ipad locked up on itunes
itunes freezes when connecting ipad
itunes freezes when i connect my ipad
itunes freezes when i pad 2 is connected
itunes freezes when ipad 4 connected
itunes freezes when ipad is connected
itunes freezing when ipad connected
itunes hangs when connecting ipad
itunes locks up when connecting ipad
itunes not responding when ipad connected
