itunes icon on initial start up
This is a discussion on itunes icon on initial start up within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I just got my first ipad 2. However in trying to set it up I can't seem to get past the itunes icon on initial ...
Results 1 to 10 of 13
    46169
    I just got my first ipad 2. However in trying to set it up I can't seem to get past the itunes icon on initial start up. Probably a simple solution I just don;t know what I'm doing wrong. Any help is appreciated.
    39964
    11
    plug your ipad into your computer?
    116 times
    15,249
    A new iPad needs to be plugged into your PC or Mac initially and you must have the latest Apple iTunes software installed on that PC or Mac. There is absolutely no way around this initial step. If you don't have the latest version of iTunes, you can download it for free from the Apple website. If you don't have access to a Mac or PC, then any Apple Store will do this for you.
    This step will initialise your iPad and transfer your email settings, contacts and other files from your PC to the iPad. It takes only a couple of minutes but saves a whole load of time subsequently - you won't have to manually set up your email etc.
    After this initial connection between your PC and iPad there is, theoretically at least, no need for them ever to be connected again - but most people do, in fact, connect them occasionally, if for no other reason than to back the iPad up.
    If you have any further questions about how to do this, don't hesitate to contact us....welcome to the Forum.....
    29345
    49 times
    Penarth, Wales, UK
    1,935
    yes, first off you need to plug your device into a computer running an up to date version of itunes.
    but i got a question about something you said, specifically....
    eh? this didn't happen for me. not manually or automatically.
    after initialising my device my contacts list on my ipad2 is currently empty and my 3 or 4 email settups i had to do manually from scratch. i have synced over some apps, vids and music, but nothing else has gone over.
    which beckons the questions, where would my pc get my contacts and email info from in the first place to copy it over? how would the pc know?
    116 times
    15,249
    Quote Originally Posted by sjleworthy View Post
    If you use Windows Mail as your email client and Internet Explorer as your web browser it will copy over the mail accounts that you have set up in Windows Mail as well as the Contacts list that you use. Similarly it will copy over your Internet Explorer bookmarks.
    If you use Web Mail, then clearly it can't do this.
    29345
    49 times
    Penarth, Wales, UK
    1,935
    ah. ok. that explains it then.
    i use firefox as my browser and dont touch MS outlook or any other computer based mail server. mine are all online and on remove company servers.
    46169
    have downloaded the latest version. When I'm in itunes I click on the itunes store and my system tells me that an error has occured and that I should check network connections. I know I'm able to get on the internet as I already have pages open. Gonna go to the Apple Store at lunch today and see if maybe they can help?
    116 times
    15,249
    Quote Originally Posted by coreybob View Post
    Did you connect your iPad to your PC with the supplied USB cable? If so, what happened? It should take you through the initialisation and setup procedure.
    29345
    49 times
    Penarth, Wales, UK
    1,935
    i also had problems upgrading the firmware this morning. half way through my usb connection dropped out. i had to restore
    46169
    Tim,
    I did connect to my pc at home with the supplied USB cable and nothing happens, other than it recognizes the ipad as a camera/scanner and asks which application I want to use to open it. None of them apply. I then go to programs and open itunes and that's as far as I can get. Thinking I should go to the itunes store I click on that and it tells me that an unexpected error has occurred, check network connections. I'm not able to connect to the internet thru itunes? I am baffled. I will say this, I'm not technologically advanced.
  1. Small Slideshow Icon on start up
    By snoozee in forum iPad FAQ
    Last Post: 01-27-2012, 05:05 AM
  2. Getting a head start on iTunes & apps
    By SunnyFL in forum iPad General Discussions
    Last Post: 07-25-2010, 09:52 PM
  3. Small slideshow icon appearing on start up
    By snoozee in forum iPad Help
    Last Post: 07-19-2010, 07:46 PM
  4. auto start of itunes stopped working
    By jrw in forum iPad Help
    Last Post: 07-02-2010, 07:30 PM
  5. Where did my App Store and Itunes icon go???
    By Finnedog in forum iPad General Discussions
    Last Post: 04-14-2010, 10:39 PM
apple ipad startup with itunes
ipad 2 startup
ipad 2 startup itunes
ipad boot itunes logo
ipad itunes icon startup
ipad starts up with itunes
ipad startup
ipad startup itunes
ipad startup itunes icon
ipad2 startup shows an itunes logo
itunes icon on ipad 2
itunes logo on ipad startup
