Wy not? I have a wifi only iPad. Do I need Internet connection to be able to use gps? Well if that's the case, good thing I never sold my garmin nuvi gps
This is a discussion on My ipad 2 mapquest gps wont work in the car within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Wy not? I have a wifi only iPad. Do I need Internet connection to be able to use gps? Well if that's the case, good ...
The WiFi-only iPad does not have GPS functionality. GPS is part of the electronics included in the 3G versions of the iPad. WiFi iPads have some navigational capability by using a database of known WiFi basestation locations. But once this type of iPad cannot receive a WiFi signal it has virtually no navigational capability.
It is possible to connect an external GPS unit to these WiFi iPads and several models are available for purchase but, if you already have a sat nav system, this probably doesn't make a lot of sense.
The wifi only iPads don't have a GPS receiver.
Only the 3G IPods have the built in GPS receiver, and that is the only reason I bought a 3G iPad.
Without jail breaking the iPad, adding a gps to a wifi iPad will cost about $100.00, and there are only three options at this time.
Rudy Ackerman
Currently on the road and homeless
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
