Results 1 to 5 of 5
    44792
    Baltimore
    33
    iPad 2 as a GPS...
    I recently lost my Garmin GPS, and I'm heading on a fishing trip this weekend. My destination is pretty remote and I lose all cell phone coverage about 1 hour out. I have a 3gWIFI iPad 2, would it be possible to use it as a GPS for the duration of my trip? Any thoughts on a good (cost effective) GPS app would be appreciated if it will work. Thanks!!
    iPad Guru
    30446
    11 times
    3,197
    Considering you have the 3G model, yes, it has GPS inbuilt and should be able to determine it's location, even when no cell towers are in range.
    For a cheap navigation app, you could use Navfree. It is available in many countries, so you only have to pick the correct version.
    iPad Master!
    545
    Feb 2010
    340
    Just a quick note, the 3G radio has to be turned on for the GPS to function. To be clear you DO NOT need a data plan, but if you put it in Airplane Mode the GPS will also turn off.
    Add 202 to my user number and call me an Airplane.
    --iPad 2 64 GB Black WiFi "Dynabook 2011. With know-how and integrity"
    624 times
    Dayton, WA
    13,315
    Also, most of the navigation and map programs need the internet to display the map. If you are out of 3G coverage you may end up with a nice blue dot on a blank page. If you don't want to buy one of the expensive apps with built in maps, I can think of two options.
    Motion X GPS, or Motion X GPS Drive. Both of these have a history buffer for maps that can be set up to 2GB. Other apps also have buffers, but I don't know how big they are. If you review the area in the map while you have internet you should have maps. This is a bit chancy,
    So my second choice is Topo Maps for iPad. While the app costs money you can download topographical maps from just about anywhere in the U.S. for free. It's a good choice for hunting and fishing, at least I think so.
    Be sure to download the maps you want before you lose cell coverage.
    Edit: Just looked up Navfree because Dont suggested it, and always has good advice. It says it keeps local maps, and since it's free I'd call it an excellent choice. I still think you'd like Topo, if you don't mind spending the money.
    44792
    Baltimore
    33
    Thanks for all of the great info. I downloaded Navfree, and did a test run on my way home this evening. Worked like a charm. I even turned off my cellular data and didn't miss a turn. Thanks again!!!
download gps for ipad 2
download gps for ipad2
download gps ipad 2
free download gps for ipad 2
free gps downloads for ipad2
garmin for ipad 2
garmin gps for ipad 2
gps for ipad2
how to set gps on ipad 2
ipad 2 gps
ipad for fishing gps
topographic maps ipad 2
