Results 1 to 3 of 3
Thread: multi tasking?
    29345
    51 times
    Penarth, Wales, UK
    1,939
    multi tasking?
    ok, whatever it's actually doing then
    i've played on it a bit and opened several apps.
    when i double press the home button i get a sub menu underneath my home menu at the bottom of the screen showing me the last several apps i was using.
    are these apps still open in memory? i think they are.
    how do i close them down permanently so they're not just always open in memory?
    thanks
    116 times
    15,249
    The iPad's operating system, iOS, is not really a multi-tasking system in the way that PC guys think - it's more of a task switching operating system. When you switch from one app to another, the app that you've switched out is suspended and its 'context' (state) is remembered by iOS. Suspended tasks can only perform a very limited range of operations. See this Apple official link for details of what a suspended app is able to do.
    What's New in iOS 4 - Apple Developer (What's New in iOS 4 - Apple Developer)
    iOS leaves recently suspended apps in the iPad's memory (RAM) until it finds it needs that space for another app. Then the suspended app is overwritten but its context is remembered.
    When the user switches back to a previously suspended task/app, if it's already in RAM iOS can immediately re-instate it and it 'comes alive' very quickly. If iOS had had to remove it to make room for another app, then it's reloaded from flash and brought up in the state in which it was originally suspended by using the context information that iOS stored when the app was originally suspended.
    When you 'flush' a suspended app by using the multi-task bar you do a couple of things. If the app is in RAM still, its space is freed up and another app can use it. If it's already been removed from RAM then its context information is deleted and iOS will forget the state that the app was in originally. Thus, when you start that app up again, it will come up in its default state with no reference to the state it was in when it was last closed (there are some exceptions to this, however, when an app itself stores context information). You flush an app by touching and holding ant app's icon until they start to jiggle - then press the '-' on the app you want to flush.
    So, when you look at the multi-task bar and see all those apps 'running' all they're probably doing is having their context remembered - a few bytes for each app stored in the iPad's flash memory. Only the most recent apps - those that are shown to the left hand side of the multi-task bar - are even candidates to be in RAM. You can usually tell which apps were in RAM by the time the iPad takes to switch back to that app when it's re-instated. Those that are 'down the list' to the right, or even on the next screen, were long ago removed from RAM.
    29345
    51 times
    Penarth, Wales, UK
    1,939
    thanks feller.
  1. Multi-Tasking Question with iOS 4.2.1?!?!
    By MSaxatilus in forum iPad OS
    Last Post: 01-12-2011, 12:38 AM
  2. When multi-tasking from?
    By ipad987 in forum iPad General Discussions
    Last Post: 11-19-2010, 01:48 PM
  3. Multi-Tasking, advantage or disadvantage?
    By Joker in forum Apple iPad Polls
    Last Post: 08-27-2010, 09:52 PM
  4. Multi-Tasking This Summer
    By DavidNM in forum iPad General Discussions
    Last Post: 04-09-2010, 08:43 AM
  5. its not multi tasking, but its goddang close
    By auspad in forum iPad General Discussions
    Last Post: 04-08-2010, 05:11 AM
app switcher for ipad 2
app switcher ipad2
best task switcher for ipad 2 cydia
how to do more than one task on ipad
how to multi task on ipad2
ipad 2 task switcher
ipad task switcher
ipad task switching
is ipad multi task system
multitasking switcher bar ipad
task switcher
task switcher ipad
