USB keyboard works with Ipad 2 strange
This is a discussion on USB keyboard works with Ipad 2 strange within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have just acquired an Ipad 2 and have read in several posts, that the camera kit dodge to get a usb keyboard functioning with ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    41864
    Bangkok
    54
    I have just acquired an Ipad 2 and have read in several posts, that the camera kit dodge to get a usb keyboard functioning with the Ipad no longer works as the power output in the latest 4.3 OS has been reduced.
    The only option is to use an electrically powered hub. I decided to go this route and buy such a hub.
    However, I have just discovered that the keyboard works WITHOUT connecting to the hub. I just plugged the keyboard in to the camera adaptor and it works.
    Any comments on that ? Am I just the lucky one or is it a fluke ?
    -keevill-
    iPad Guru
    30446
    11 times
    3,197
    Using USB keyboard's should generally be possible, only sometimes does it not work.
    But I don't actually know why. My first iPad 2 did not work with the external USB keyboard, but after exchanging the iPad does the USB keyboard work, also without a powered hub.
    The powered hub's should only be needed for devices, which draw a higher current then the iPad can supply, 10mA.
    44652
    Modesto
    65
    thats kinda cool and i might have to pick one up that that works with a keyboard
    41864
    Bangkok
    54
    Quote Originally Posted by DontUnderstandMyIpad View Post
    Perhaps some USB keyboards draw a little less than the 10mA limit ?
    That would explain it would it not ?
    -keevill-
    iPad Guru
    30446
    11 times
    3,197
    Quote Originally Posted by keevill
    -keevill-
    Well, the keyboard did not work with the initial iPad 2, but now works with the replacement i2. So considering the current drawn by the keyboard stayed the same, it is not entirely clear, why the keyboard did not work initially.
    The keyboard in question is a MS Natural Ergonomics 4000.
    46405
    6
    This is a bit off topic but I'm just gonna ask anw. Im planning to get a 16gb iPad 2 and thinking of expanding its storage with sd card or usb stick, but I hv read a few post saying the problem with iPad 2's power output. So since you have the powered usb hub, could you try to connect a thumbdrive to iPad 2? I know this could be done with iPad 1 but given the reduced voltage thingy that Apple did to iPad 2, this is no longer possible.
    iPad Guru
    30446
    11 times
    3,197
    I don't think thumb drives work without a jailbreak, which is not yet available for iPad 2. Btw. a powered hub is not necessarily required for thumb drives, my Kensington stick works directly from the camera connection kit. And since the current limit is the same on iPad 1 and 2, should it still work, once a jb is made public.
    46405
    6
    I did some research around and it all said the current is limited in iPad 2. Thats what they said anw.
    Also, there is a way to connect a USB to iPad 1 that is to format your usb stick to Fat32 and create a folder name DCIM and put your stuff inside that folder to trick iPad 1 into thinking its a camera. Now thats what they did before the jailbreak was available, so I wonder if I can do the same for iPad 2?
    iPad Guru
    30446
    11 times
    3,197
    Quote Originally Posted by nguyen
    Neat trick.
    Works a treat on iPad 2. I created a DCIM folder on a Kingston thumb drive, filled it with a few images and they than showed up in Photos. But of course does it not read any other files.
    I think both iPad 1&2 limit the current to 10mA.
    46405
    6
    Thats nice... how big is your kingston thumb drive? It'd be great if you can test usb with larger storage, see what the limit is. Im also interested to see if other thumb drive that previously showed the "not enough power" message could do the same...
  1. Replies: 6
    Last Post: 01-20-2012, 07:33 AM
  2. A strange question on ipad's safari
    By pandajj in forum iPad Development
    Last Post: 02-10-2011, 03:14 AM
  3. strange email on iPad
    By DrBailey in forum iPad Help
    Last Post: 11-27-2010, 09:46 AM
  4. A very strange iPad occurrence
    By Tlpaduser in forum iPad General Discussions
    Last Post: 09-18-2010, 03:10 AM
  5. Strange iPad behavior, possible virus or defct?
    By Ultrimate in forum iPad General Discussions
    Last Post: 07-18-2010, 10:39 PM
how to connect usb keyboard to ipad
how to connect usb keyboard to ipad 2
ipad 2 keyboards with usb
ipad 2 usb keyboard
usb keyboard for ipad 2
usb keyboard ipad 2
usb keyboard ipad2
usb keyboard on ipad 2
usb keyboard with ipad 2
using a usb keyboard with ipad 2
using usb keyboard with ipad 2
