WiFi issue with I-Pad2
This is a discussion on WiFi issue with I-Pad2 within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Good Evening folks! Hey have any of you had an issue with WiFi signal, or reception? Let me give you two examples. I take the ...
Results 1 to 10 of 17
    12352
    Aug 2010
    MA
    11
    Good Evening folks! Hey have any of you had an issue with WiFi signal, or reception? Let me give you two examples. I take the train into Boston every day, and the week i got my new shiny I-Pad2 i was showing it to my friend and well his Ipad found the trains WiFi with no problem and my wonderful new I-Pad 2 could not? and then mutiple time since then the connection is not that good. The the second example is when my youngest child in nappin in the car, one of us sits out with them. Our Ipad gets our WiFi with no issues and is pretty fast... the lovely NEW Ipad2 is iffy at best. what gives? anyone got any great advice?
    Link the Lover of all Ipad
    39943
    Southern California
    21
    I did experience some wifi difficulties at home. My wireless router kept resetting. I *think* that I solved the problem by updating the firmware on my router (D-Link DIR-655). So far so good.
    116 times
    15,249
    41464
    12
    I have some issues with the WIFI on my Ipad 2 63gb/3g, it seems to have poor reception which varies wildly with no change in any other variable. Also on a speedtest, you can see lots of jagged graph and a drop off in sustained data transfer with time.
    side by side with my macbook air, the air gets 56+mb/s on my N wireless network (Airport Extreme, feeding from a fast cable connection), the iPad peaks out between 2mb and 12mb/s on the same network, same distance same location etc.... I think the wireless drivers need some attention.
    I tried the old trick of turning off the autobrightness and it improves a little but still slow.
    Would appreciate others experience and ideas please.
    116 times
    15,249
    One of our moderators suggested this...
    "This has resolved many issues and worth a try.
    __________________
    Cheers
    Col
    col.bris, Brisbane Australia"
    45431
    19
    Apple needs to address this issue and they need to do it NOW. Simply inexcusable. I even went to an apple and asked an employee about it and all they could say was they've never heard of such a thing, must be my network etc. WRONG. It's the damn iPad. Fix it apple. This is getting old really quick.
    41889
    Erith United Kingdom
    161
    Quote Originally Posted by Link1369NY490
    The best thing to do is to return the iPad 2.
    Happy to be Appy to be iPaddy to be iPoddy
    45431
    19
    Lucy you can edit your post by clicking on the blue downward arrow. No need to dbl post
    12352
    Aug 2010
    MA
    11
    Thanks so far, i will try all the above, EXCEPT the "return thrnI-Pad2" one. Thanks anyway! LOL.
    Link
    12352
    Aug 2010
    MA
    11
    Quote Originally Posted by iRockSteady
    Ya know... After a few more days of needing to reboot the WiFi to get it to sign on line... Even thugh it is says i "am on line" but i get NO reception i am agreeing with iRockSteady!!!! They need to fix this... The i pad 1 is better when it comes to WiFi connection. BUT so far that is my only complaint.
    ;0)
  1. Wifi issue at hotel - help!
    By ThePhotog in forum iPad 2 Forum
    Last Post: 03-19-2011, 07:28 PM
  2. Just ordered my i-Pad2
    By Avista in forum New Member Introductions - Site Assistance
    Last Post: 03-12-2011, 04:57 AM
  3. wifi issue
    By Driver in forum iPad Help
    Last Post: 12-16-2010, 02:22 PM
  4. Wifi Issue with OS 4.2
    By aramb in forum iPad Help
    Last Post: 12-11-2010, 03:55 PM
  5. WiFi issue
    By bruce24 in forum iPad Help
    Last Post: 08-05-2010, 11:41 AM
apple safari problems with i pad2
connect ipad to d-link dir-655
dir 655 ipad wifi
fix my wifi on i pad2
i pad2
increase wifi speed ipad2
ipad 2 not holding wifi signal
ipad 2 poor wifi
ipad problem wifi teltra
ipad wifi trein
pad2
wifi antina week signal in ipad2 after screen
