Verizon connection issue
This is a discussion on Verizon connection issue within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I am more than a bit frustrated with the connectivity issue with Verizon. I have followed the instructions... Called the 800 number when rejected 3 ...
Results 1 to 7 of 7
    45145
    I am more than a bit frustrated with the connectivity issue with Verizon. I have followed the instructions... Called the 800 number when rejected 3 times.. Was transferred twice..and still not connected... The last rep said I should go to the local target store for help even tho I ordered the iPad from apple. Advice out there.
    iPad Enthusiast!
    39988
    89
    Well what exactly is the issue? Are you not able to connect to 3G?
    iPad Enthusiast!
    39988
    89
    No I can connect just fine now but I was having the problem. I called Verizon and they walked me thru some steps and I haven't had the issue since. I suggest calling them. I've been trying to recollect my thoughts on exactly what they had me to do but I don't remember. Whatever it was, it worked. This was about 3 wks ago and I haven't had an issue since
    45145
    I followed the directions for connecting and was directed to an 800 #. That is when the transfers of calls began. The latest was my call to apple where they directed me backnto verizon. Not sure what to do at this
    Point
    iPad Enthusiast!
    39988
    89
    So u paid for data and u aren't able to use it. When u set the data up there was an 800 number there. 800-769-8419
    45145
    Did that. No luck. Worked today tho
    iPad Master!
    36745
    Boston
    346
    It's not a problem with Verizon, it's an Apple issue. Some Verizon iPad 2's have a problem connecting to 3G. Apple is supposed to be issuing a firmware update soon.
    Not every Verizon iPad 2 has the problem, mine connects perfectly and was quite easy to set up.
  1. Replies: 3
    Last Post: 04-10-2011, 08:17 PM
  2. Ipad connection issue
    By Skynetkernel in forum iPad Help
    Last Post: 04-08-2011, 11:11 PM
  3. So Verizon is better than AT&T?
    Last Post: 02-16-2011, 10:53 AM
  4. Internet connection issue
    By HB24 in forum iPad Help
    Last Post: 01-29-2011, 11:21 PM
  5. Replies: 3
apple and verizon connection issues
verizon ipad not connecting
verizon ipad not connecting to internet
