Sorry if this has been asked before, but does the iPad2 have stereo speakers built in?
This is a discussion on Does the iPad2 have stereo speakers? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Sorry if this has been asked before, but does the iPad2 have stereo speakers built in?...
Nope, only mono.
I don't think it really matters with the internal speakers since you can't really get the fully stereo effect, but if you listen through earphones or speakers, it will be in stereo.
It's loud!
And the speaker is still at the bottom, I take it? Meaning if you want to dock it, you have no choice but to use the Aux line out on top, correct?
The speaker is on the bottom, but more directed towards the back of the device pushing the sound away. I like the first generation design better personally.
It's a hard placement. With the tapered edges there isnt much choice unless you want to put them behind the bezel and punch holes there. Although if they had gotten speakers on both top and bottom (left right in landscape) I thing the effect would have come off a bit better instead of making me feel like I'm lossing hearing in one ear.
Watch for a apple patent that will cover transmitting sound through solid glass and metal/plastic.
Add 202 to my user number and call me an Airplane.
--iPad 2 64 GB Black WiFi "Dynabook 2011. With know-how and integrity"
Talk about hard core metal!!!Originally Posted by Thphilli
Wait isn't aluminum metaloid? Can I borrow 13$. Need to buy elements app.
[COLOR="] If you don't know me by now, I will never ever ever leave Apple. [/COLOR]
No it doesn't. You can get a good stereo sound with ear phones tho.
