AirPrint Activator Help
This is a discussion on AirPrint Activator Help within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Downloaded the AirPrint and did it right...I think. I've gotten two different message in the command prompt. One says FAILED & Access Denied. The other ...
Results 1 to 5 of 5
    43121
    4 times
    DC
    242
    Downloaded the AirPrint and did it right...I think. I've gotten two different message in the command prompt. One says FAILED & Access Denied. The other opens and closes the connection. Any ideas on what I can do to get this install successfully?
    Attached Thumbnails Attached Thumbnails AirPrint Activator Help-capture.png   AirPrint Activator Help-capture-2.png
    119 times
    15,248
    OK - I had this exact same problem and I'm trying to remember how I eventually fixed it. It's all to do with the cupslite issue that you see reported.
    This may be a bit of a trial-and-error process - try AirPrint.exe -r and this should remove everything and try again.
    I'm not with my PC at the moment but, if it doesn't work, get back and I'll have a look and see if I can recall what I did to finally get it to work.
    43121
    4 times
    DC
    242
    Figured it out
    Thanks Tim, I figured it out. I had to right click on cmd and select run as administrator before entering the code. It works great now.
    119 times
    15,248
    Quote Originally Posted by jasmynsway View Post
    Glad it worked OK. One other problem that I had was that when I take my laptop away from home and then return it sometimes gets allocated a different IP address by my ADSL broadband router and that confuses the iPad.....so I'd be interested to hear if you have the same problem. In the end I configured my laptop to have a static IP address when it's at home.
    43121
    4 times
    DC
    242
    Interesting. I'll have to check that out.
  1. Windows 32/64 bit AirPrint Activator
    By iPadPil in forum AirPrint
    Last Post: 04-16-2012, 08:26 PM
  2. Using AirPrint with non-AirPrint printers?
    By nateccnn in forum iPad General Discussions
    Last Post: 01-07-2011, 10:09 PM
  3. AirPrint
    By Pluto5680 in forum AirPrint
    Last Post: 11-23-2010, 10:53 AM
  4. Activator installed but no icon
    By 0sync0 in forum iPad Hacking
    Last Post: 08-14-2010, 01:46 PM
  5. Activator 1.40 and touch screen sensitivity issue
    By aratheba in forum iPad Hacking
    Last Post: 07-24-2010, 07:49 PM
airprint activator
airprint activator for ipad
airprint activator for ipad 2 download
airprint activator for windows
airprint activator for windows 7
airprint activator troubleshooting
remove airprint activator
uninstall airprint activator
Tags for this Thread
