iPad 2 and iTouch Sync Questions
This is a discussion on iPad 2 and iTouch Sync Questions within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I've searched and found a few references to my question, but I'm still somewhat confused.
I currently have an apple account and and iTouch 2nd ...
I currently have an apple account and and iTouch 2nd Gen. I'm considering purchasing an iPad 2, WiFi version. Here are my questions:
1. Do I need a new (and separate) account for my iPad?
2. I will have some of the same apps on both my iPad and iTouch and will have some apps on one but not on the other. If I set up for a manual sync and plug in my iPad, will it only sync the stuff related to my iPad and not the stuff for my iTouch (and vice versa).
3. Since #2 above is is what I want to occur, is there any special setup or procedure I need to follow when setting up my iPad for the first time or, subsequently, when I attach one of the two devices?
4. Will the automatic backup that currently occurs when I sync my iTouch be maintained separately from the automatic backup that I presume will occur when I attach my iPad?
5. When I use a file sharing app on, say, my iTouch and select a file currently on my desktop, will this file also show up on my iPad if I have the same app on the iPad (or, again, will they be kept separately?)?
If I haven't asked a question that I should have asked, I would appreciate any advice other users of multiple apple devices could provide.
Thanks.
04-06-2011 12:07 PM
Originally Posted by
Tomel
1. Do I need a new (and separate) account for my iPad? No use the Sam Appl I'd
2. I will have some of the same apps on both my iPad and iTouch and will have some apps on one but not on the other. If I set up for a manual sync and plug in my iPad, will it only sync the stuff related to my iPad and not the stuff for my iTouch (and vice versa). ITunes will handle the sync for you. You can set what apps, photos, etc. You want synced to either device. When you connect the device iTunes will recognize which one it is and sync appropriately.
3. Since #2 above is is what I want to occur, is there any special setup or procedure I need to follow when setting up my iPad for the first time or, subsequently, when I attach one of the two devices? When you connect your iDevice, you can set up what to sync. I recommend tha the first thing you do is to tell iTunes to sync manually.
4. Will the automatic backup that currently occurs when I sync my iTouch be maintained separately from the automatic backup that I presume will occur when I attach my iPad? Yes it will.
5. When I use a file sharing app on, say, my iTouch and select a file currently on my desktop, will this file also show up on my iPad if I have the same app on the iPad (or, again, will they be kept separately?)? This I don't know since I have no tried it.
I have no trouble with both my iPad and touch and keeping them both in sync. ITunes handles this very wee.
Thanks.
iPad Enthusiast!
Tomel
Thanks.
1) No. You can use the account you use for your ipod touch.
2) You can manually select which apps you want to load into your idevices, even if it isn't ipad compatible there's the 2x at the bottom right of the screen so you can enlarge the app but it will be pixelated.
3) Refer to Answer #2.
4) Your iTunes recognizes your devices, therefore it doesn't overwrite thr backup data.
5) Guess you are refering to DropBox kind of app? If so then it should show up on your ipad as well since dropbox doesn't store your data locally.
Hope i've helped
iPad Enthusiast!
Double posted accidentally.
No. Just use the same Apple ID (account) that you presently have.
The current apps that you have that are compatible with the iPad will work.
Jbembenek
Sorry about the double post. Fingers faster than my brain.
Jbembenek
My question,query is that I want to stream music from my itouch to my iPad. I really don't want to have to leave my laptop on for this. Could I jam pack a 64 gig itouch with music, videos and stream them to a 16gig iPad is basically my question. Hopefully using Bluetooth or wifi..
- You may not post replies
- You may not edit your posts
Forum Rules
By toddw in forum iPad Help
Last Post: 04-05-2011, 07:56 AM
By Digikid in forum User News Submissions
Last Post: 09-16-2010, 06:32 PM
By Links80 in forum iPad General Discussions
Last Post: 07-24-2010, 01:11 PM
By mamajag in forum iPad Help
Last Post: 06-27-2010, 01:13 PM
By MikesTooLz in forum iPad Apps
Last Post: 05-30-2010, 12:12 PM
how can i get mytown2 to sync to my ipad
how do i sync my ipad2 to my ipod touch
how to sync itouch to ipad2
ipad bluetooth synch
sync ipad 2 and ipod
sync ipod to ipad 2
sync ipod touch 2nd gen and ipad2
sync ipod with ipad 2
sync itouch vice versa
syncing ipad 2 with ipod
syncing ipod to ipad 2
syncing ipod with ipad 2
