Wifi loosing connection
This is a discussion on Wifi loosing connection within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Is anybody suffering from this problem? After a week of extensive usage I had this issue; I loose wifi connection every now and then with ...
Results 1 to 10 of 10
    42754
    21
    Is anybody suffering from this problem? After a week of extensive usage I had this issue; I loose wifi connection every now and then with my home network. And I cannot have it back until I reset my router. At the beginning I thought it might be a router issue BUT other devices at home had no problem at all. Plus today I had the same problem when connected over my iPhone's personal hot spot. Did not get it back until I restarted the iPhone.
    Any clue?
    42754
    21
    I have ipad2 32 gb wifi+3G. (3G not activated yet)
    42250
    Riverside, CA
    100
    I have a 64 GB with 3G I use wireless at home and thank God I have not had a problem
    38851
    El Paso Texas
    I had the same issue and after giving my iPad a fixed ip the issue has been fixed. This is the case especially if you have a 2 wire router. Good luck
    11919
    9 times
    Aug 2010
    Virginia, USA
    718
    I would suspect your router
    Fortunately they are cheap. I have no problems anywhere with either my iPad or my iPad2. No losing connections.
    If my Irish Wolfhound doesn't like you neither will I.
    2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
    39127
    4 times
    just outside of philly pa USA
    347
    i have not had that problem with my ipad 2
    39481
    4 times
    448
    I think I have lost connection a few times. My 3G bill says I have been using it at home. I didn't notice the switch until I seen the bill.
    I have turned the 3G off for a few days and haven't lost connection during those days.
    64GB 3G White iPad
    iPad Enthusiast!
    43784
    Atlanta, GA
    82
    I have had issues with disconnects when connected to my 5G wifi, but when I switched over to the 2.4g connection the problem stopped.
    iPad Enthusiast!
    39679
    Somerset
    39
    Quote Originally Posted by Misho73 View Post
    Any clue?
    My hotspot also not as perfect, but mostly because of iPhone not ipad2.
    42754
    21
    Thank you guys for the input. I have searched the issue and obviously lots of people had it
    I've tried couple of things; reset the network and disabled the 3G
    So far so good.
    Will let u know if the trick worked.
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. wifi connection
    By lou in forum iPad General Discussions
    Last Post: 02-17-2011, 07:56 AM
  3. Always use 3G, even with Wifi connection
    By DontUnderstandMyIpad in forum iPad General Discussions
    Last Post: 01-23-2011, 12:15 AM
  4. WiFi connection
    By fusdma in forum iPad Help
    Last Post: 12-13-2010, 02:11 PM
  5. Replies: 3
apple tv keeps losing connection
apple tv keeps losing connection with ipad
apple tv keeps losing wireless connection
apple tv loses connection with ipad
apple tv losing connection
ipad and loosing hotspot
ipad losing connection with apple tv
ipad losing connection with appletv
ipad2 dropping wireless connection
iphone hotspot drops connection
iphone hotspot keep alive
keep iphone hotspot alive
