Wireless keyboard
This is a discussion on Wireless keyboard within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have an Apple wireless keyboard but can't figure out how to make it work with my iPad. Does anyone know?...
Results 1 to 10 of 12
    37501
    Virginia
    32
    Wireless keyboard
    iPad Guru
    30446
    11 times
    3,197
    Yep.
    Go to Settings->General->Bluetooth->On, now press on the keyboards right side the power button until the light flashes.
    The keyboard will show up on your iPad, click on it, enter the passcode on the keyboard, press enter and you are all set.
    iPad Enthusiast!
    21687
    Nov 2010
    USA
    37
    All you have to do is go to settings --> turn on bluetooth and the ipad should find the bluetooth keyboard. It will tell you to punch in some numbers in the keyboard and it will be paired.
    116 times
    15,249
    Quote Originally Posted by melsnel View Post
    Have you used the Apple wireless keyboard previously with another computer? If so, it has to be 'un paired' (reset) before it can be 'paired' with the iPad. Bluetooth devices can only work with one device at a time - otherwise confusion could result - if there were two computers in range of the keyboard, which one is it supposed to be controlling?
    So the first thing, if the keyboard has been used previously, is to reset it.
    Then 'Settings', 'General', 'Bluetooth' -> On and the iPad will go into discovery mode. When it finds your keyboard you can select it and pair it with the iPad. This usually - depending on whether it's been connected previously - needs you to type in a pairing code - the default is usually '0000' - but the iPad might suggest one that you have to type on the keyboard.
    Once you've done that you're good to go and the keyboard and iPad will 'remember' each other from then on.
    If you have any further issues with the keyboard, please get back to us.
    116 times
    15,249
    Wow - so many helpful people in the Forum - thanks, guys!! It's great to know that there are so many of you kind ladies and gentlement out there.
    37501
    Virginia
    32
    Thanks guys! Now all I have to do is figure out how to un-pair it from my Mac and I'll be all set. I think that will be a job for after lunch.
    iPad Guru
    30446
    11 times
    3,197
    There is no need to un-pair. The bluetooth keyboard only pairs with one device, so if you follow on of the above procedures to connect it with your iPad, will it automatically forget the device it was previously paired with.
    37501
    Virginia
    32
    Thanks!!! I will try that. Looks like it will have to wait until tomorrow. Busy, busy day! You guys are great
    37055
    San Francisco
    5
    I'm having problems with repeating key syndrome with my apple wireless keyboard. The only solution is turning off keyboard and bluetooth and reconnecting. I've read on some forums that updating keyboard's software might solve this. But I can only find directions to update if you're using keyboard with a mac. I'm a PC guy. Any suggestions?
    37165
    Minnesota
    363
    Thumbs up Apple Wireless Keyboard with iPad2
    UPS just delivered my new keyboard from Apple. I do a lot of writing and blogging and I need a full keyboard for entry. I also have the iAWriter app and it works so slick... Also Pages app. I am not really looking for a typical laptop, but wanted flexibility. Now I have it.
    I considered Zaggmate ... but after digging into some in depth reviews discovered the keyboard is small like a netbook ... some keys are rearranged and the corners of the protective case dig into wrists. (didn't want to have to relearn years of keyboard habits). Can't charge the Zagg integrated keyboard while in the case. While it is a nice integrated case. For $100 spent I have a better deal. I wanted a great keyboard ... Apple is it. Got it from Ebay and saved $30 (new in a box... 3 days shipping ... great timing). Also the keyboard works with my Mac Mini should I chose to pair it up that way.
    I also have the protective case from Targus VUScape. I really like it. Just wanted to share ... for what it is worth for others trying to decide.
  1. wireless keyboard
    By bcardin6969 in forum AirPrint
    Last Post: 03-20-2011, 10:41 PM
  2. Apple's Wireless Keyboard vs. Matias Wireless Folding Keyboard
    By WannaBeMac in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-23-2011, 08:36 PM
  3. Wireless keyboard
    By ncyrider16 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 12-30-2010, 12:00 AM
  4. Apple wireless keyboard
    By dennis in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-13-2010, 09:17 AM
  5. Wireless Keyboard
    By joe.niles in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-03-2010, 09:03 PM
apple wireless keyboard ipad repeating keys
apple wireless keyboard repeating keys
apple wireless keyboard reset
how to reset apple wireless keyboard
how to reset apple wireless keyboard from pairing
how to reset imac wireless keyboard
how to reset mac wireless keyboard
reset apple keyboard pairing
reset apple wireless keyboard ipad
reset apple wireless keyboard pairing
