iPad 2 CC Kit woes
This is a discussion on iPad 2 CC Kit woes within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Does the iPad 2 have different USB specifications then the iPad 1? When plugging in USB devices, it gives no message, not even the "Device ...
Results 1 to 5 of 5
    iPad Guru
    30446
    11 times
    3,197
    When plugging in USB devices, it gives no message, not even the "Device is not supported" one. I have tried to connect a MS Natural Ergonomic 4000 keyboard to it, but nothing happens not even a message of an unsupported device shows up, but when connecting the same keyboard to an iPad 1, it shows the "Device not supported message" and works.
    Has anyone else experience similar difficulties?
    iPad Addict
    27034
    5 times
    Dec 2010
    Gettysburg, Pa
    1,237
    What if you used a powered USB hub since cck only outputs 20mA now...not enough power for keyboard. Not what I would want to do though. Too much trouble.
    Banned
    10565
    16 times
    Jul 2010
    Va
    1,251
    Quote Originally Posted by DontUnderstandMyIpad
    Great observation. I was contemplating that same notion based on ipad2 users post on the subject in other threads. So apple really ceased the support on ipad2. So ipad1 has an advantage in this category. Or could it be the new 4.3 or 4.3.1 causing that issue. I'm still onm4.2.1 ;-)
    Sent from my Jailbroken IPad on 4.2.1 ;-)
    iPad Guru
    30446
    11 times
    3,197
    It really looks, as if Apple has restricted the iPad 2 USB functionality.
    The keyboard does not even work, when it is connected to an externally powered hub. Very frustrating.
    It either is an 4.3.1 issue, or with the iPad 2, as the test iPads are iPad 1 4.3 and iPad 2 4.3.1.
    I will update the iPad 1 to 4.3.1 to see, if that is the reason, if not a return of the CC kit will be a likely result.
    iPad Addict
    15631
    2 times
    Sep 2010
    Sydney
    1,078
    I am typing this on my USB keyboard, running 4.3.1 on 1st generation iPad, so it's not a 4.3.1 issue or limitation.
    32GB WiFi
  1. DVD conversion woes...
    By Alixen in forum iPad General Discussions
    Last Post: 03-01-2011, 08:34 PM
  2. Calendar woes.............
    By blowabs in forum iPad Help
    Last Post: 07-13-2010, 01:45 PM
  3. Calendar woes....
    By blowabs in forum iPad General Discussions
    Last Post: 07-12-2010, 07:22 PM
how to connect usb keyboard to ipad 2
ipad 2 usb not enough power external fix
ipad screen repair
usb 20ma cck ipad
usb device not supported error
