Targus vue case owners
This is a discussion on Targus vue case owners within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Heres a couple ideas first off I love this case! Same price as the smart cover, but I think that the apple smart cover is ...
iPad Enthusiast!
Heres a couple ideas first off I love this case! Same price as the smart cover, but I think that the apple smart cover is defiantly overrated! Now I have the TARGUS VUE SMART COVER I think it is the first out there? the placement of the magnet activated the sleep mode on and off, with no problem I just used my dremeled tool and made a small hole for my magnet and hot glued it that's it I think it looks kind of cool leaving the silver magnet exposed I was gonna paint it but decided not to. also when you shut this thing the latch really didn't seem to catch very good so I heated the latch with my heat gun till it got soft " it's plastic under the leather" and then shut the case and reformed it against the I pad and now it is a secure latch when I close it it stays closed it's awesome ! Just ordered my I skin CARBON for the front and back then the IPAD 2 will be complete thanks for looking
04-01-2011 11:12 AM
Targus PivotVU or VUScape
Originally Posted by
jimmy4fingers
Heres a couple ideas first off I love this case! Same price as the smart cover (snip) ! Just ordered my I skin CARBON for the front and back then the IPAD 2 will be complete thanks for looking
I have the same protective cover. The stand setup of three angles is slick. I haven't done the magnetic thing yet...but I will. My cover latch works perfectly... great protection, front, back and corners ... cutouts are perfect for port and control(s) access.
Why the Skin Carbon? I don't see the need ... why do you?
iPad Enthusiast!
madhatter61
Ah just in case plus it looks cool it has the front one to that covers the bezel
This is really helpful man. Thanks a lot. I have the targus cover as well and I have been trying to figure out how to add a magnet just for convenience and coolness sake because the sleep button is still really accessible even with the cover closed.
Where did you buy the magnet? Is there any reason why you put the magnet on top instead of inside? I am thinking of adding another one at the lower part just to make it look symmetrical. I'm one of those symmetrical freaks. Love the logo piece at the center.
norwei
I found a small magnet on a tire gauge I bought a long time ago, $3. Go to an auto parts store. The magnet has fairly strong attraction force.
I cut a small slit in the inside protective material just past the sewing. Leave the sewing alone. Then the magnet just slips under the material. A little elmers glue enabled the flap to be captured. Looks quite nice. Works very well. What is nice about this approach is the magnet is covered so it doesn't scuff. It is close to the front edge so it doesn't interfere with the typing position setup.
Hi folks, I will be holding off on adding the magnet to my targus case. I was browsing in amazon and I saw the Toblino 2 case which looks very similar to the targus case but with the magnet already built in. It also says it's made of real leather so I ordered it and scheduled delivery is Tuesday. So if that one works out great, I will be returning the targus case.
- You may not post replies
- You may not edit your posts
Forum Rules
By NLAlston in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 02-27-2011, 12:20 PM
By Snarky30 in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 12-18-2010, 01:48 PM
By Wakawaka in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 10-11-2010, 10:20 PM
By TFarmer in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 09-10-2010, 11:09 AM
By gentlefury in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 05-30-2010, 02:04 PM
how to add a magnet on a targus - vuscape cover for apple? ipad? 2
how to add a magnet to the targus - vuscape cover for apple? ipad? 2
paint targus case
targus ipad case problem
targus magnet
targus magnet case
targus vue
targus vue problem
targus vuecase
targus vuecase ipad
targus vuscape magnet
targus vuscape vs toblino 2
