Interested to know what ipad2 users recommend to keep battery life/longevity optimum.
What will be the cost to have factory replace one?
camman123
camman123
One thing I've read is that its better to use up most of the battery before recharging it, instead of topping it off constantly.
Get a battery maintaining app like Battery Doctor Pro or Battery Magic.
iPad-2 White WiFi 64GB
iPod Touch 3G 32GB
Do those actually work?Originally Posted by Tom P.
Lithium Polymer prefers being topped off as opposed to being fully drained but will perform well in either case for a long time.
The tech support man at Apple said a battery replacement is $100
LP batteries usually get about 500 charge cycles before seeing any discernible drop in performance but that is an average, YMMV. Each time you plug your iPad into a power source is a charge cycle whether it fully charges or not.
Hope that helps
Support Our Troops!
This post was Tapatalk approved
Sent from my iPad
Apple has a page with a few tips: Apple - Batteries - iPad
In particular they say:
"For proper reporting of the battery’s state of charge, be sure to go through at least one charge cycle per month (charging the battery to 100% and then completely running it down)."
If, for whatever reason you were to leave your iPad unused for a long period of time (say you're going on a gadget-free 2 week holiday) then leaving the battery charge at around 50% is ideal for battery health.
Agree though that with Li batteries, you don't want to be draining all the way and then recharging all the time. Ideally try to avoid going below 20-30%.
If you want the technical 'low down' on Lithium Ion batteries, have a look here...
Charging lithium-ion batteries – Battery University
