I can turn my ipad2 all the way down but I still hear sounds from certain things like AIM and the lock/unlock sounds. Anyone else seeing this?
This is a discussion on Volume all the way down but still hearing sounds. within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I can turn my ipad2 all the way down but I still hear sounds from certain things like AIM and the lock/unlock sounds. Anyone else ...
Two places you go to change these volume levels and turn on/off various options are:
Settings >> Notifications
and
Settings >> General >> Sounds
As donka said, the mute switch can turn these all off quickly.
In iOS 4.3 and above, depending on how you have it set this is either the switch above the volume rocker, or it is found in the multi-task bar by double clicking the home button and swiping right.
I have my switch set to orientation lock.
Found the "change with buttons" settings. Thanks for the heads up.
